2007 maxima blowing cold air when idle?
Old Nov 14, 2014 | 06:10 AM
jmcman13's Avatar
I have a 2007 maxima with 191k miles. I recently noticed when I put on the heat, it is cold at idle, but when I start driving its hot again. Anyone know what this can be? Why the hot air is cold when the car is stopped?
Old Nov 14, 2014 | 11:30 AM
po8pimp's Avatar
You have air in your coolant. You need to burp your coolant system. You can search on how this is done on YouTube. Very easy. This has been covered on this forum before as well. You can search above in the 6th gen section. Good luck, let us know if you have any questions.
Old Nov 14, 2014 | 02:19 PM
DennisMik's Avatar
This is a classic sign that the coolant in the radiator is starting to get low. When the engine is cold, remove the radiator cap and check the coolant level. The radiator should be totally full, not a bit of air.
If you can, do this when the nose of the car is slightly inclined. It helps to get air pockets out.
maxinout93
Oct 27, 2015 01:29 PM
cheftoo
Aug 20, 2015 05:17 AM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
