Heat doesnt work at idle..
Old Feb 9, 2015 | 10:52 AM
Costa068's Avatar
I'm having a problem with the heat in my car... When I'm driving it cranks... But the moment I slow down the heat cools down. I added more coolant. Maybe not enough? Any suggestions on what it could be?
Old Feb 9, 2015 | 02:53 PM
chrome91's Avatar
so was it low on coolant? if it was low on coolant as in the reservoir was empty and the radiator was very low, that will mean no heat
if it wasnt really low on coolant, thermostat is the cheapest and easiest place to start
Old Feb 9, 2015 | 04:35 PM
Costa068's Avatar
It was low.. I added more but I see that the level has lowered a little... Maybe there is air in it?
Old Feb 9, 2015 | 06:42 PM
chrome91's Avatar
if the coolant hasnt been changed recently there wouldnt be air in the system. if the radiator was low you have a leak somewhere probably
Old Feb 16, 2015 | 09:25 AM
Kevon1's Avatar
Same problem here. Bleed the system for air that was not the culprit.........Flushed the system and heater core......Kind of the problem......Car at the dealership having the heatercore replaced as I type. Thank God its covered .
Old Feb 25, 2015 | 11:49 AM
DeusExMaxima's Avatar
Park the car on an incline and top off the radiator. That ensures all the air is out of the system because the radiator top will be higher than the rest of the cooling system.
Old Mar 4, 2015 | 05:37 PM
po8pimp's Avatar
holy crap haven't seen anything posted from you here in a while. You gonna be autocrossing again this year? It was nice keeping up with your build and adventures with the maxima. good to see you back on the threads.
dr3am
25
Oct 22, 2015 08:53 PM
tnewbs
Aug 28, 2015 10:15 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kenc15
Aug 5, 2015 08:29 AM
