install remote start
Old Mar 2, 2015 | 06:53 AM
herring's Avatar
I was just wondering if its possible to install a remote start in a 2007 maxima while retaining the original maxima remote. Ive seen 5 button remotes with one button for remote start. How hard would it be and where can I get the hardware? Thanks!
Old Mar 6, 2015 | 09:47 PM
Mrbizness1's Avatar
I have a 07 with a remote start. I use the factory remote, tap lock three times to activate it. A separate remote is inconvenient. It will cost more
Old Mar 8, 2015 | 12:17 PM
herring's Avatar
Thanks for the reply.. So how do I get the stock remote start? My car doesn't have it..
Old Mar 8, 2015 | 03:36 PM
george__'s Avatar
Not worth the headache. More power drain, more electronics that could potentially blow up etc
Old Mar 8, 2015 | 03:52 PM
jwsvtcobra01's Avatar
factory fob remote start
its extremely easy any installer at any shop can do it for you, basically just have them install a standard remote start such as a viper or any DEI brand, this will come with 2 remotes which u can keep at home for times you may need extended range as the factory fob don't have as much range as after market, also tell them you want it on factory fob lock 3x, a lot of bypass modules will do this automtically now a days, but even if they use a brand that doesn't you can have the installer wire a relay to the lock MOTOR wire convert that (+) pulse using a relay to a (-) pulse and then that gets attached to the start activation wire on the remote start brain, (white/blue) stripe wire on DEI products, this may all sound complicated but any installer should have absolutely no problem doing this for you at all
Old Mar 8, 2015 | 07:50 PM
Mrbizness1's Avatar
Mine is made by Directed Electronic. Most alarm shops use this or similar stuff. some shops install systems using separate remotes which to me is inconvenient having to carry two around. Mine is like 5 years old so thing probably changed. I used a shop that installs for new car dealers also, so their alway seem to use the newest stuff. jwsv is correct, factory remotes do have less range. Call a local shop and see what they have.
Old Mar 9, 2015 | 07:15 AM
mvodnansky's Avatar
Avital system has been great for several years for me! It's a tiny additional one button remote that is on a key ring connected to my key fob. It also has very long range.
http://www.avital.com/Products/Remot...5005/4113.aspx
Old Mar 9, 2015 | 06:20 PM
Mrbizness1's Avatar
Looks like a nice system, did a Google search. Several shop in my area use it.
Cotozic
Jun 28, 2017 08:01 PM
ah2002
Mar 9, 2016 01:42 PM
305head
Aug 26, 2015 09:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
maximaham
Aug 7, 2015 01:11 PM
