Horn Problems - 6th Generation (2007)
Old Dec 10, 2015 | 11:59 AM
Howardst22's Avatar
Hopefully someone can help me! The horn (when pressed on the steering wheel) doesn't work, it did work intermittently for the past few months but nothing anymore. When I set the alarm, the horn works fine but nothing when I try pressing it on the steering wheel. The car won't pass the freakin emissions testing here in TX, not to mention the safety issues...I'm sure it's the fuse since it works when using the fob key...Any ideas??
Old Dec 10, 2015 | 02:16 PM
Costee's Avatar
That's sometimes the symptoms of a failing clock spring (spiral cable). Other controls on the steering wheel might soon also become dysfunctional.
Old Dec 10, 2015 | 02:33 PM
Howardst22's Avatar
Ok, thank you for the info. I seen a couple posts just now about the spiral cables. Going to do a little bit more testing on the wheel to see what's all working? Is this a relatively easy repair &/or something that I can do without getting raked going to the dealership? Thanks again!
Old Dec 10, 2015 | 02:39 PM
Costee's Avatar
Relatively easy repair if you're sufficiently inclined. The FSM contains instructions on disassembling and reassembling.
Old Dec 10, 2015 | 08:18 PM
Mrbizness1's Avatar
Whats the emission problem, SES light on?
Old Dec 11, 2015 | 09:51 AM
Howardst22's Avatar
There's not an emission problem. I don't see an SES light come on. Checking for a functional horn is just a part of the inspection they do & they won't pass the car if it's not working. I did check yesterday after reading thru a couple posts. The horn will only work when I turn the wheel all the way to the right or all the way to the left.
Old Feb 2, 2016 | 12:30 PM
Howardst22's Avatar
Finally got around to doing this repair. The part was $222 (cheapest I found anywhere). A relatively easy repair, and all is working fine now. Thanks for the info and advice!
Old Aug 26, 2017 | 09:29 PM
Sanjay Vyas's Avatar
Hello,
Did your clock spring have 2 or three cables? how about the connectors on back,,,1 or 2? i ordered a part and it come with only the two cables and 1 connector...and all places i got to are referring to same part! mine has 3 cables in front and 2 connectors in back.
please let me know.
thanks
Old Aug 29, 2017 | 12:52 PM
Howardst22's Avatar
Hello! I don't recall off the top of my head but I do know there's 2 different part numbers, one for the heated steering wheel and one without. The one that I needed was for the heated steering wheel (listed below).
NISSAN 25560ZK01D GENUINE OEM MULTIFUNCTION SWITCH
( 191648713794 )
Maxboy23
Nov 25, 2015 03:26 PM
Wjanifer1
Nov 22, 2015 08:49 AM
bperryman21
Nov 17, 2015 11:57 AM
TheGroceryGetter_A32
Nov 12, 2015 10:05 PM
TxBroncosFan
Nov 12, 2015 12:07 PM
