Altenator symptoms ???
Old Dec 14, 2015 | 07:46 PM
Pnjboyzz's Avatar
Hi guys,
My 04 max started to fail sensors...
I accelerate the gas and cranck shaft sensor failed... It was replaced.
The few days again I accelerate the gas and cam shaft sensor failed . the another sensor failed next to cam shaft sensor..
Now when I accelerate the gas harder again, it pop up the abs, break light and battery light.
Abs light went off after few seconds but break and battery light is still on. I have this altenator replaced 1 year ago after market.
I been reading altenator symptoms and I think it might be altenator going bad.
Can altenator fail other electronic parts ?
Old Dec 18, 2015 | 10:10 PM
DennisMik's Avatar
if the voltage created by the alternator is too high, yes.
The brake and battery lights on together mean the alternator is not charging. You can confirm this by taking your voltmeter and measuring the voltage while the engine is running. the reading should be between 14.0 and 14.5 volts.
Old Dec 20, 2015 | 09:14 PM
Pnjboyzz's Avatar
thanks for your time.
yes it turned out to be alternator
D Mason
Jun 21, 2016 04:43 AM
TKHanson
Oct 19, 2015 10:50 PM
TKHanson
Oct 14, 2015 06:07 PM
memphisballer
Oct 12, 2015 09:23 AM
ef9
Oct 4, 2015 08:43 AM
