Cooling fan
Old Feb 20, 2016 | 11:52 PM
Luis Orozco's Avatar
Cooling fan
Hi my name is Luis
An I own nissan maxims 05
An I notice that my cooling fan is not turning it only turns went
I turn on the ac besides that it dozen
Can someone help find the problem
Old Feb 23, 2016 | 11:23 PM
DennisMik's Avatar
If the cooling fans do not run, the car will over heat. Does your car over heat?
The cooling fans do not run all the time when the air conditioning is off.
Old Feb 24, 2016 | 04:29 PM
NIKV69's Avatar
Yes let car sit and idle without AC on and see if it kicks on when car reaches hot temp. If not could be coolant sensor.
Old Mar 7, 2016 | 05:37 PM
2k0to2k3's Avatar
Where is the coolent sensor? Specs diagram?
Old Mar 7, 2016 | 10:33 PM
DennisMik's Avatar
You did not answer the question - Does the engine overheat?
Here is a link to the service manual:
http://boredmder.com/FSMs/Nissan/Maxima/2005/
To locate the Engine Coolant Temperature Sensor (ECTS), follow the upper radiator hose to where it attaches to the engine. 2 or 3 inches after that is the ECTS.
See page 222 in this link for information about the ECTS.
See page 491 in this link for information on how the cooling fans work:
http://boredmder.com/FSMs/Nissan/Maxima/2005/EC.pdf
Old Mar 28, 2016 | 08:07 PM
Linhnb's Avatar
My car got over heat when the engine is running and the car is not moving for a while. fan on passenger side is not running.
Does anyone know how to diagnose this problem?
Old Mar 29, 2016 | 08:51 AM
NIKV69's Avatar
Here is a good place to start.
https://maxima.org/forums/5th-genera...t-working.html
Old Mar 29, 2016 | 11:08 AM
wingnut2006's Avatar
There are two (2) each relays for the cooling fans. The relays should be the same number. Reverse the relays and see if the fan on the passenger sides works. If you have the same condition as before then the fan motor is bad. If the passenger side works and other does not then the relay if bad.
bbsitum
Feb 20, 2016 12:05 PM
gerardamorris
Jan 26, 2016 03:19 PM
