Nissan maxima ignition switch problem?
Old Feb 19, 2016 | 12:36 PM
bbsitum's Avatar
I have exactly this symptoms
Dan Levine
“I have a 1997 From what gather.These Nissan Maxima's are known for bad ignition switches.Is this true?In order to get my car to startup I have to wiggle like crazy with the key.Been like this for 2 yrs.Now it's becoming worse to start.I never changed the ignition switch.Is it known for the key ignition to go bad or just the ignition switch??”
But this answer
bordmder
“Dan Levine Generally what you're describing is a typical symptom of a bad ignition switch. Pull it out and start it with a screwdriver, see if it'll start every time like that.?”
And then this
Dan Levine
“boredmder It was the ignition switch.The plastic hole on the switch for the tumbler gets warn from metal on plastic use.I just simple placed a piece of duck tape over the tumbler turning thing and re-installed the switch.Works like a charm now lol.?”
Should I try tape first too or go to junkyard and bring a ignition switch.
Old Feb 19, 2016 | 12:48 PM
DBear's Avatar
Don't use duck tape, it will eventually slide out. Try this: https://maxima.org/forums/4th-genera...ml#post8875419
JvG's Avatar
JvG
You could try the tape I suppose.
The ignition switches do fail. I've replaced mine at least twice during the past 10 years and 100k miles.
New switches are thirty bucks or so.
Dice new ones don't last forever, why would you want to drive to the junkyard to buy a used switch which will fail sooner than a new one?
I could understand if you want to sell the car soon.
bbsitum's Avatar
That guy at youtube even said that some guy at ".org" with name DBear recommend electrical tape at metal part.
Old Feb 19, 2016 | 12:49 PM
bbsitum's Avatar
So you are that one.
Old Feb 19, 2016 | 04:02 PM
bbsitum's Avatar
Well I "fix" problem. Open it easy. Was possible to se at plastic part strong 1/16 dent left by metal tong. I just role aluminum foil and put at that place. Work for now. I will let you know if it fail.
Old Feb 19, 2016 | 05:24 PM
JvG's Avatar
JvG
So the problem was mechanical instead of electrical.
Your solution was creative and free. Thanks for letting us know.
Old Feb 20, 2016 | 12:05 PM
bbsitum's Avatar
Why I like talk how I'm smart all what I did here was Google "Nissan maxima ignition switch bad" and post at this forum. There was video what to do, how to fix and what are symptoms. So no much at my part.
DLMAXIMA
Dec 25, 2019 02:31 PM
chevyman1980
Jan 3, 2016 11:46 AM
Bluz
Dec 19, 2015 09:26 PM
Joseph88
Dec 9, 2015 11:14 AM
