P03030 Engine code
Old May 6, 2016 | 09:47 AM
eastsidemoon's Avatar
P03030 Engine code
Last night my car started acting up out of nowhere. Its shaking at low RPM, has very little throttle, and the check engine light came on. I went to Autozone today to have it scanned and it came up with Code P03030. I was told it is a misfire in the 3rd cylinder, most likely because of a bad ignition coil. Anybody ever have experience with this engine code? Was this the fix? I did change my spark plugs about 15,000 miles ago and there does not seem to be any vacuum leaks.
Old May 6, 2016 | 04:51 PM
NIKV69's Avatar
Could be an injector too. You have to test the coil first and make sure it's not bad.
Old May 7, 2016 | 12:38 PM
wingnut2006's Avatar
Computer is saying that there is a misfire on cylinder #3. There could be several problems the most likely is either the coil or spark plug (you could have cracked the plug during installation), bad injector or low cylinder pressure. Without thousands of dollars of equipment you can only change the coil and plug and hope that it corrects the issue. Be sure and use only OEM plugs. If you used another brand or type of plug 15,000 ago, be sure and change OEM type at this time. Good luck
gwmac
Mar 12, 2016 06:55 AM
ShunDoe
45
Mar 8, 2016 07:52 PM
DuckSauce
Mar 8, 2016 04:05 PM
slickblack94
Feb 29, 2016 10:33 AM
ZerotoSixty
29
Feb 29, 2016 05:13 AM
