Starting problems
Old May 18, 2016 | 07:33 AM
maxima4826's Avatar
Starting problems
I have a 2008 Nissan 3.5Se and sometimes when I go to start it, it'll crank over but it'll take a couple seconds of holding the key (longer then it should take) any reason why that is? Thinking the fuel pump is taking a crap
Old May 18, 2016 | 10:38 AM
wingnut2006's Avatar
Camshaft sensors normally causes a hard start or delay start. May or may not turn on check engine light.
Old May 18, 2016 | 10:43 AM
maxima4826's Avatar
So it could be camshaft or fuel pump most likely?
Old May 18, 2016 | 04:56 PM
NIKV69's Avatar
Could be many things. Could need new plugs. Any codes?
Old May 18, 2016 | 06:29 PM
maxima4826's Avatar
What do you mean by codes? Nothing is popped up on the dash if that's what your asking. I'd say like once a day it'll crank over longer then it should so I'm thinking it's the fuel pump.. Hopefully cause I think a fuel pump is about $60
Old Jun 22, 2016 | 10:12 AM
BETO6700's Avatar
Did you figure the problem? My car is doing the same thing, I have to keep turning the key and pump the gas. It takes longer in the mornings
Old Jul 5, 2016 | 04:10 AM
maximatech12's Avatar
Sounds like what the Service adviser at Nissan said was a starter in my Maxima. It kept getting worse then I needed a tow.
ctwoody
Aug 9, 2016 01:28 PM
cocovation
Jun 20, 2016 10:44 AM
zoemayne
May 15, 2016 07:45 AM
camako
May 15, 2016 03:43 AM
cariannechase@gmail.com
May 13, 2016 10:53 AM
