Error Code P0720 for 2000 Nissan Maxima
A few weeks ago, my car began intermittently not going over 30 miles per hour. When I would step on the gas, the rpm gauge would peg all the way to the right.
Around the time this started, my "Service Engine Soon" light came on. When I took the car to AutoZone to have the codes read, one of them came up as P0720, and I was told this was for a vehicle/transmission speed sensor.
in the Haynes manual for my car, the part referred to as a speed sensor looked like this: http://shop.advanceautoparts.com/p/c...208/20473323-P. My Haynes manual also said the sensor could be accessed by going under the hood. I bought the sensor, replaced it Sunday, and cleared out the code.
My car was fine until Wednesday night when it started the intermittent not going over 30 miles per hour again. The "Service Engine Soon" light came back on, also.
I did some research, and it appears there may be more than one sensor called a speed sensor. I found some things, including a You Tube video, which state that there's something called a speed sensor which is accessed by removing the front driver wheel. I found another part called a speed sensor on Advance Auto Parts' website that matches the one in the You Tube video: http://shop.advanceautoparts.com/p/d...m=speed+sensor. However, if this sensor is discussed in my Haynes manual, I can't find where.
Since replacing the one sensor didn't work, should I go ahead and try replacing this other one? Has anyone else with a 2000 Nissan Maxima GXE had this issue? Does the car have more than one speed sensor, or are either of the sensors I mentioned above called by something else?
Thank you.
Thank you.
Thank you.
Thank you.
, but heres a spoon fed link anywayhttps://maxima.org/forums/5th-generation-maxima-2000-2003/563476-tranny-missing-p0720-help-please.html
Did you replace both speed sensors? i believe there is an upper one ontop of the tranny and a lower one based on that thread i peeked at.
A Tale of Two Sensors
Google is your friend
The sensor you need generates an electrical signal for the TCU/ECU ("revolution' sensor). You can buy it here http://www.rockauto.com/en/moreinfo....359222&jsn=447 , about $75.
JM AUTO RACING
Nov 21, 2017 08:24 AM
jj9711
Jun 30, 2016 12:56 PM
valerit1
May 19, 2016 04:13 PM
bbsitum
Feb 20, 2016 12:05 PM
