Need help : tach/rmp drops by 500 rmp while at low speeds
Old Jun 20, 2016 | 12:41 PM
madhat311's Avatar
Hey guys i have a 07 maxima with 118k miles. Car runs great minus the strange issue over been having.
While I'm going slow 20 to 40mph and I let off the gas the car will go from 1500 ish rpm and drop to 1000, then back to 1500. There's no loss of power, doesn't feel like it's trying to change gears and no jolt like from the motor.
I noticed it after I fixed a p0345 code which was the cam sensor Bank 2, not saying it wasn't happening before that but if it was I never noticed it
It happens with the ac on and off. I've replaced both came sensors, and the crankshaft sensor. In the process of changing the vacuum lines from the vacuum tank located under the plastic engine cover because I noted one was dry rotted.
I'm lost at this point, I have no codes and for the most part the car runs great minus this issue. Heres a video of the problem so you can see it in action
Thanks for you time, I appreciated it.
Old Jun 20, 2016 | 12:51 PM
madhat311's Avatar
Oh I wanted to add that the drop will occurr once then return to its proper rpm until I touch the gas , then it will do it once more and return to normal.
Old Jun 21, 2016 | 05:28 PM
ef9's Avatar
ef9
That's the exact same issue I am having. See my post below. Although no one responded.
Old Jun 21, 2016 | 05:42 PM
madhat311's Avatar
So I think I have it narrowed down to the vias vavle , I ordered it and I'll let u know how it goes when I get it on thursdsy
Old Jun 24, 2016 | 09:55 PM
ef9's Avatar
ef9
Hi,
Did you get the new VIAS valve?
Old Jun 25, 2016 | 03:41 AM
madhat311's Avatar
So I did get the valve and new vacuum tubing, the issue is better but not fixed.
I'm thinking it maybe ( what nissan calls the power valve actuator) which is attached to the vacuum tubing from the new vias
And I'm having a hard time finding this part online , I'll have to go to Napa or autozone.com when I get the time
Old Jun 25, 2016 | 12:04 PM
ef9's Avatar
ef9
Thanks for the update.
Is it the Vacuum Switching Valve that you plan on replacing?
Old Jun 29, 2016 | 10:50 AM
ef9's Avatar
ef9
Did you get a chance in replacing the vacuum switching valve?
Old Jul 15, 2016 | 05:38 PM
madhat311's Avatar
i did replace the valve , still the same story. my water pump did go bad and when i took it to the shop one of the guys said it might be the CVT trans causing the issue. So it currently at nissan dealer and im waiting to hear back from them
Old Jul 15, 2016 | 05:53 PM
ef9's Avatar
ef9
Thank you for the update!
Old Jul 23, 2016 | 04:34 AM
madhat311's Avatar
Well , **** it .. maxima is sold. I took it to the dealer for a water pump issue , turns our they said my issue seemed from a oil leak in the valve cover that was dripping into one of the sparkplug. Cost to fix 1800 usd. Also they said I needed a timing chain job which was 2500 plus 900 for the water pump. Oh and they wanted to replace both motor mounits at 355 each .
So I'm the proud owner of a 2016 hyundai sonata now.
On a side note I was concerned it was the cvt Transmission that was causing my rpm issue ( so says my normal mechanic ) buy he didn't have the tools to really dove into it. I feel since I was at 199996 miles when I dropped it off and the cvt warranty ends at 120k they wanted to point to anything but the tranny until I drove 4 more miles .
Can't prove it but that's my feeling. Just the fact that it would only drop rmp once till you touched the gas points to it not being a spark issue in my opinion
Old Jul 23, 2016 | 10:53 AM
ef9's Avatar
ef9
Thank you for the update.
On my situation, I don't think it's a valve cover issue, as I bought brand new valve covers(you can't replace the spark plug tube seals).
Also, I changed the timing chain and everything on that side of the motor.
Old Jul 23, 2016 | 11:26 AM
madhat311's Avatar
Like I said I'm pretty sure it's something to do with the cvt
JM AUTO RACING
Nov 21, 2017 08:24 AM
Levsimus
Apr 13, 2016 10:25 PM
cardana24
Feb 12, 2016 09:45 AM
jnm2kse
Aug 29, 2000 06:55 AM
Shingles
Aug 28, 2000 01:10 PM
