Power steering pump/ cv boot/ tie road end all soaked in engine oil. Thoughts?
Old May 21, 2020 | 03:44 PM
LeakyVQ's Avatar
Here’s the story. I’ve been chasing oil leaks with this motor for awhile now. The cars been sitting for about a year. It’s a VQ35DE out of a 05 maxima that I swapped into my Sentra.
I just got done redoing the oil cooler gasket, timing cover, front seal, rear main, and the two half moons of the upper oil pan.
Did them all out of the vehicle to get them perfectly sealed. This helped tremendously however I’m still getting this leak that absolutely SOAKS my p/s pump, the banjo bolt p/s hose that runs from the resivour down to the pump, cv boot and tie road end boot.
The valve covers looked pretty dry and I replaced them 2 years ago so I’m not thinking that’s the issue.
I also haven’t replaced the oil pressure sensor yet since it seems unlikely it would consistently spray High enough up to get to the p/s.
Anyone have any experience with this?
Old May 21, 2020 | 05:39 PM
User1's Avatar
Keep an eye on power steering fluid level. Beyond that, and getting underneath it while it was running and leaking, which none of us here can do, no clue.
Old Aug 19, 2020 | 01:17 AM
DPenfield's Avatar
Same thing was happening to mine. I have a 2008 and everything seems to go wrong. I traced mine up to the power steering reservoir. The res was fine, but the hoses coming from it were old and worn . It cleaned everything up, disconnected the hoses, trimmed the ends that connected to the reservoir , wrapped the tubing with self sealing auto tape and put new clamps on when I reconnected it. It's been fine every since with no leaks. But that's also when I realized there is something going on with the power steering pump itself also. Check all hoses, clamps and belts
JAmerican
50
Jun 8, 2013 12:06 AM
hotrodder
27
Jan 29, 2010 10:16 PM
mrkanda
Jan 12, 2009 06:55 AM
TysMadmax
Jun 15, 2007 06:31 PM
gibsot
Mar 30, 2001 11:02 AM
