front control arm broken bolt
Old Jun 17, 2020 | 07:32 PM
Mharvey500's Avatar
Hi, this is 2004 Maxima and I need help to remove a broken bolt. It is the inner bolt of the two bolts attaching the control arm to the front suspension member. There is about half an inch of bolt sticking through the top of the suspension member where I can grab with vise grips. After copious PB Blaster it still won't move. It is too close to the bushing attaching the suspension member to the chassis to apply heat.
If I use only one bolt the bracket might tend to twist when there is lateral force such as acceleration or braking. Any ideas on extracting that bolt or is there another solution?
Old Jun 17, 2020 | 10:16 PM
User1's Avatar
Post a picture.
Old Jun 18, 2020 | 05:07 AM
Mharvey500's Avatar
The threaded portion of the bolt is stuck in the suspension member above the control arm with half an inch sticking above I can grab with vise grips.
Old Jun 18, 2020 | 06:17 AM
Mharvey500's Avatar
Old Jun 18, 2020 | 11:22 AM
Mharvey500's Avatar
The bolt is broken where my finger nail is. The portion above is inside the suspension member with the half inch unthreaded portion sticking above for vice grips.
Old Jun 18, 2020 | 01:13 PM
User1's Avatar
Ok cool. Doesn't look that bad. You need to drill a series of holes through the bolt shaft. I would start small and drill in three steps/increasingly larger bits. This will relieve tension on the bolt. Get a nice big extractor and go from there. Get a good, sharp (sharp is key) punch to start your pilot hole. Sucks working upside down but I don't know of any other way to attack this.
Old Jun 18, 2020 | 02:14 PM
Mharvey500's Avatar
Here's another wrinkle. I've got the bolt wiggling just a little but not like it wants to go further. It feels like the nut built into the member is moving. I'll let you know what happens.
Old Jun 18, 2020 | 02:20 PM
User1's Avatar
Rust is a B i t c h.
Old Jun 18, 2020 | 06:52 PM
Mharvey500's Avatar
Bolt extracted from top of suspension member. Using vice grips. Bottom grinded down first to remove any damaged threads. Mission accomplished.
Old Jun 18, 2020 | 07:14 PM
User1's Avatar
You lucky dog.
rbuswell
29
Apr 14, 2015 09:34 AM
VQP0WER
Jul 31, 2010 01:26 PM
t0p_sh0tta
Aug 28, 2008 02:36 PM
MrGone
Nov 21, 2003 07:37 AM
