Can it be fixed? Lower Control Arm bolt
Well, of course the last bolt I needed to remove in order to pull out my knuckle was stuck. Had to cut the dang nut off and in the process, jacked up the lower control arm (transverse link) bolt. Looks like this swivel type bolt is pressed in somehow.
I'm thinking I need to get a new lower control arm, but has anyone repaired this before?
this is why i just replaced the entire control arms assembly...that bolt you jacked up is the bolt i had to cut to get the damn assembly off
you can buy just that piece and have it pressed in...when I did mine I checked: advance and auto zone both carry them
lol. The wife couldn't figure out wtf I was doing. Cussin inside the garage with sparks flying everywhere from my grinder. Then the damn nut finally came off with the air chisel.
wish you needed something else...i have two completely good LCAs in my garage...except for that part i had to cut
I guess if my noobish self would have realized that was the lower ball joint and not just a "bolt", I could have properly searched these forums where I got numerous hits.
Some people say they can be punched out, others say replace the arms. I'm too tired to figure out what I'm gonna do.
So Jason, you got two control arms with no ball joints installed?
you can replace just the *****...but seemed like a pain to me so i just did the entire thing (from dave b)
go to a place where you can rent/borrow a tool and ask for a ball joint remover. It will take you 5 minutes to replace the ball joint.
http://www.sears.com/shc/s/p_10153_1...u=00915822000P
I used this one to do 3 maximas a few weeks ago.
Remove the snap ring from around the top then either use the ball joint press to remove it or hammer it out. I had this problem after I changed my wheel bearing, I had a hard time getting the nut out and I messed it all up.
After you get it out, just line the new ball joint up underneath, if you get MOOG, leave the grease fitting off till its pressed in. I think mine was around 40 dollars off amazon with 2 day shipping. Once you get it lined up, use an impact or 1/2 inch drive(whatever you choose to use) with the ball joint press and press it in straight, put on the snap ring and you're good to go.
I first tried pressing it with a C clamp but I just bent the clamp handle. Next morning I went to pep boys, rented the tool for free (100 dollars deposit) and finished pressing it within 2-3 minutes.
I cannot for the life of me figure out how to use this ball joint press. It came with like a dozen different adapters. arg..
Anybody know what piece of this press goes where in order to press this thing out?
Good Luck
I finally got it. Got almost everything put together just to find out the threads at the end of the CV joint are all messed up and the nut won't go on. Tried grinding it down but with no luck. Looks like I'm gonna get a new CV joint now....lovely.
The Frye
09-02-2021 11:03 AM
