Oil galley gaskets.
Old Mar 16, 2021 | 01:32 PM
Gjkdc's Avatar
Oil galley gaskets.
I am replacing the timing chain on a 2005 Stock Vq with 110k. Is it common practice to replace the oil galley gaskets while I am in there or just leave well enough alone ? Do they go bad? I don't want to have to remove the front cover ever again
Thank you...
Old Mar 17, 2021 | 05:19 PM
TDGrant's Avatar
Cheap and easy...then get it done. Like you said, you don't want to take it apart again.
Old Mar 17, 2021 | 07:03 PM
Gjkdc's Avatar
I'm seeing / hearing that people change out the slotted screws for a hex style. Easier torque down and removal. Do I just find those screws where ever I can?
Old Mar 17, 2021 | 10:05 PM
aackshun's Avatar
Whoever sells those gaskets sells the hex screws with it for an extra charge.
I've removed enough stock screws successfully without ever having to need the hex screws but if it's your first time, hell get the hex heads.
BUT if you do the job right with an impact screw driver then you'll have great success, yes.
Don't forget to buy new VTC o-rings and hell if you plan on taking high rpm trips above 6500 then get a rev-up oil pump, also replace the water pump o-rings while you're in there.
Oh and for the love of god, do NOT replace a 6g with stock 6g timing equipment, it's pure HOT GARBAGE, buy oem timing for a 350z (03-06 Z if you're a 04-08).
Old Mar 18, 2021 | 06:53 AM
Gjkdc's Avatar
Does the gallery gaskets in the maxima (2005 in my case) correspond to the Z or ant other models. I would like to buy OEM if I could. If not Z1 motors ports site may have sone. You can't buy the oem Maxima gaskets separate from the TC cover but I see OEM gasket sets for the other models or engine type VQ35DE?
Old Mar 20, 2021 | 09:10 AM
Gjkdc's Avatar
AAckshun,
Thanks for the advice. Researching the oil gallery gaskets, I come across two types. The first is a set made from a composite called Syntheseal. Z1 sells those. The second type is from Nisformance. The set they sell is a metal reinforced composite that I ASSUME is closer to the newer OEM style. Any wisdom that can be bestowed upon me as to which is better? I might be overthinking these gaskets.
Thank you
Old Mar 20, 2021 | 11:42 PM
aackshun's Avatar
03-06 z parts all work in 02-08 Maximas.
bbsitum
Mar 4, 2025 04:27 AM
dan1el
73
Jun 25, 2016 05:04 PM
Algertron
Aug 21, 2008 10:35 AM
snair2
Jul 18, 2005 08:12 PM
