Sputters and backfires
Old Jul 18, 2021 | 09:46 AM
thadeadpool's Avatar
Any ideas on on sputtering and back fires for my max?
Old Jul 18, 2021 | 09:59 AM
TDGrant's Avatar
https://www.carrsubaru.com/service/i...averton-or.htm
Old Jul 18, 2021 | 10:00 AM
TDGrant's Avatar
I suspect a timing issue. Timing is off (due to worn chain tensioners / stretched timing chain), or your crankshaft sensor / camshaft sensors are sending incorrect timing information to the ECU.
Old Jul 18, 2021 | 10:11 AM
Thanks for responding, would a non skilled person such as myself be able to do this? And what would be your best guesstimate for cost of having a shop do this?
Old Jul 18, 2021 | 10:17 AM
TDGrant's Avatar
You can easily do the sensors. Timing chain stuff, on the other hand, is not for the beginner.
First, you have to figure out (diagnose) what the issue actually is. You don't want to start throwing parts at it, for that gets very expensive and usually does not resolve the issue.
Stuff like your issue is tough. I would just take it to a shop to be diagnosed. Mechanical stuff you can see (brakes/suspension) are far easier to deal with because you can see it. That is not your case, so I would get it diagnosed and then figure out what you want to do.
Old Jul 18, 2021 | 10:20 AM
10-4 sir thanks for you advice!!
Old Jul 18, 2021 | 10:25 AM
TDGrant's Avatar
No problem. Hopefully some others on this forum will have something to add as well, which might narrow it down a bit for you.
silvermax2k2
Aug 17, 2005 10:27 AM
ms.thicknes
61
May 6, 2002 04:27 PM
NYCe MaXiMa
Jul 29, 2001 04:09 PM
