2006 Nissan Maxima/ clueless
Old Apr 24, 2022 | 11:26 PM
9mm_mama's Avatar
I keep getting p0340 and c1130 codes! I have done so much to this car already and I did it myself… however with these codes I have changed bank 1 and bank 2 and the car will have the RPMS fluctuate and then the car stalls and loses all power. I can put the original bank 1 and bank 2 sensors in and the car will run again temporarily! I have no clue what to do next besides try a new pcm! We have also checked wires and relays. Please someone help me!!!
Old Apr 25, 2022 | 04:03 PM
Costee's Avatar
Did you replace with oem sensors? Maybe the ABS module is failing too. You may disconnect it and see what happens.
Old Apr 25, 2022 | 08:59 PM
9mm_mama's Avatar
I did not originally use oem camshaft sensor! They were cheapies and the original ones are reinstalled now. I did just order my oem camshafts for bank 1 and bank 2 and a crankshaft. I have questioned the pcm as well… because if the car stall and loses all power you can unplug the connector to bank one wait about 5 minutes plug it back in and drive another 50 or so miles! When I unplugged and cleaned connectors to the pcm it seemed as if it reset everything. BUT only temporarily where is the abs module in the car
Old Aug 22, 2022 | 03:16 AM
mabsarer22's Avatar
Nope, mines not equipped with one. Even if it was, the car was off before I got in.
Old Aug 18, 2024 | 03:59 PM
mabsarer22's Avatar
I was in the car less than 30 seconds before i touched the wheel and noticed that it was hot, nowhere near enough time for it to have gotten that hot
Kraig Massee
Mar 10, 2021 11:58 AM
Maxima Dan
Dec 15, 2015 08:14 PM
MAXIMA_STYLE
22
Feb 19, 2009 11:08 PM
PoePoe2797
May 2, 2004 10:42 AM
