Help!! Leaking trans cooler line
Old Oct 21, 2022 | 03:22 AM
Jonrt87's Avatar
I got a leak ever since I replaced my radiator the transmission cooler line been leaking and I know why because the trans line going in the radiator isn’t secure enough or tight enough there’s still some wiggle room and I wanna know what I could buy to make it as tight as possible so no fluid will leak out the side of the trans line
Old Oct 21, 2022 | 02:47 PM
TDGrant's Avatar
I would think about getting another trans cooler line. Maybe there is an issue with the threads on yours. However, if it is still loose, then you need a better quality radiator. You don't want to run the tranny dry.
Old Oct 21, 2022 | 03:28 PM
Jonrt87's Avatar
I know that’s my next step if this doesn’t work I got some JB Weld on it right now to see if that fixed the problem
Old Oct 22, 2022 | 06:31 PM
mustang86's Avatar
been there and i know how frustrating these can be. Anyways you need to change entire rad as i could never found the connector , some AN connector i bought but never fit in the radiator. I didn't buy a new rad, only bought a trans cooler ( Hayden) and ended with a separate cooling for trans oil. its easy and you can do it by yourself. Just make sure to put the cooler in front of rad and close to condenser.
Maxicab
Nov 11, 2019 07:54 PM
kevin007
Oct 24, 2007 01:13 PM
jaxima
May 28, 2001 07:31 PM
