canister vent valve open when ignition on.
Old Feb 10, 2023 | 05:58 PM
rickcioppa's Avatar
Ok, so I have a 2005 Maxima and I'm chasing a P0444. I have tested Evap purge valve and closes and holds vacuum. But the canister vent valve remains open after ignition is on. I have tested the vent valve by using a ground on chassis and using the power lead from the harness with ignition on and it works fine and holds vacuum. I do not have a bi-directional scanner so I can't remotely close vent valve. Any ideas would be appreciated. Thanks
Old Mar 23, 2023 | 08:16 AM
twilson542's Avatar
Any update on this? I am having same issue. Starting to think it is the wiring connector.
Old Mar 23, 2023 | 08:32 AM
rickcioppa's Avatar
Yes, mine ended up being a wire connection at the harness where you plug in.
Old Mar 23, 2023 | 08:47 AM
twilson542's Avatar
Just grabbed one on Rockauto. That's an expensive connector. Thanks for the reply.
Lumpy971
Jul 18, 2015 01:09 PM
asand1
Jul 11, 2014 03:08 PM
FunLovinMaxima
Sep 30, 2007 05:45 PM
Phantoj
Mar 20, 2003 10:46 AM
jlee4
Jan 3, 2003 02:43 AM
