2008 opinions
Old Jan 12, 2024 | 03:11 PM
Ms.Nicole80's Avatar
2008 opinions
Is 2008 nissan maxima a good year car?
Old Jan 12, 2024 | 07:13 PM
vebong's Avatar
I think it is the 2nd model year with the the CVT
Old Jan 13, 2024 | 01:15 AM
Yea i have a 2001 nissan maxima se for 9 yrs now . best car ever. Strong engine. I looked at a 2008 today , ended up not getting it. Drove it a couple blocks , looked under the hood and the radiator was smoking!
Ive replaced many things on my car over the years and i have always looked to this org. For opinions, answers, or just read up on certain issues. So i appreciate your reply.
Old Jan 13, 2024 | 08:50 AM
RA030726's Avatar
I'm nutty for Nissans
Some issues a family member had on a 2007 (owned since new): engine burns oil, radiator cracked, multiple air con leaks, ignition coils failed, steering shaft failure, clock spring failure, fuel gauge, power seat. The trans is still going but feels strange at slow speeds. Then there's the rust depending on your climate. Check the floor pans and exhaust for rust. After that there are multiple regular wear items to check, especially rubber parts like bushings and engine mounts.
Old Jan 13, 2024 | 08:52 AM
Maxgig's Avatar
IMO mostly all Maxima's are pretty good cars, if they are properly maintained. I've personally owned 3 over the years, a 97 SE, 5 speed, with 152k miles. A 2003 SE, 6 speed, with 160k miles and now a 2010 SV, currently with 198k miles and counting. If the radiator was smoking on the car you drove it was due to be changed, which is an easy fix. The radiators on these cars are made of plastic and after 15 years would definitely need to be replaced. The only reason I skipped buying a 6th Gen Maxima was because I didn't like the "toaster" sunroof on them. Other than that, I think they are good cars.
Old Jan 14, 2024 | 11:28 AM
2002SEMT's Avatar
It's not if you have an automatic transmission. I would never own an unmodified Max. Mine is a 2004 with a 2019 engine.
SamDaniel2020
Sep 26, 2023 06:03 PM
1Sickmax
Jun 9, 2011 01:09 PM
dkmura
24
Feb 11, 2009 01:28 PM
msoemax
Jun 9, 2005 02:34 PM
