Slip light issue
Old Mar 8, 2024 | 08:48 AM
Nateg12's Avatar
Slip light issue
Hey, i have a 07 maxima se.
Been having the abs issues. Changed the abs sensors and rear hubs, that solved part of the problem. I also got another abs module and installed it, doesn't solve my slip light issue. So i put the original one back in.
So what im dealing with is: when i start to apply some throttle (over 1500rpm) the slip light comes on and stops all power etc. if i turn vdc off the car runs fine without problems.
Has anyone had or solved slip light issues?
Old Mar 9, 2024 | 08:15 AM
Roblee22's Avatar
Yep, I currently still have an abs issue that i have had since I owned the car, I’ve yet to replace the sensors or module, in the meantime, I disabled the abs by removing an sensor from one of the rear wheels(you can remove the abs fuse, but that also disables alot of other systems in the car). I also, have to turn tcs off for like the first 5 or 10 mins of driving until the system completely disables, I’ll update once I get some new parts in.
Old Mar 9, 2024 | 01:19 PM
Nateg12's Avatar
Okay thanks for your response. My rear bearings didn't have a great magnetic strength anymore for the sensors to read off of.
PGT186
24
May 29, 2017 02:29 AM
infinitiblast
Aug 10, 2010 06:48 AM
GreenVQ30
Jan 14, 2008 04:31 PM
sinewave
Apr 21, 2001 10:17 PM
