My first problem.
Old Jun 29, 2009 | 10:02 PM
  #161
lightonthehill's Avatar
Originally Posted by marmstro
I'm having a problem with the passenger side airbag light going on and off while I'm sitting in the seat, even when just my purse is in the passenger seat.
Vibrations at all speeds. Knocking especially obvious when backing out onto the road from my driveway. Happens while turning now as well.
Question???? - Shouldn't the driverside door lock feature still allow the driver to operate all the windows? Mine only allows me to operate my window if I lock the rest out.
Have an appointment tomorrow but the dealership is no longer loaning cars, they say. So I guess I'm supposed to pay for two cars I'm not sure I want. Don't most dealers at least rent you a car if they can't loan you one.
I'm regretting the decision to ever purchase a Nissan.
marmstro - There have been several posters here who have had trouble with the right seat airbag on/off situation when the person riding there is only around 115 pounds or so. Are you around that weight?
'Vibrations at all speeds?' Do you mean the front passenger seat (several here have had the right front seat vibrate rather badly while driving down the road) or the whole car? I think there is a fix somewhere her on the board for the right front passenger seat vibration, but if the whole car vibrates, it could be any number of things. But your car should not have significant vibration. That tells us something is not right. Tires/wheels/alignment are often the culprit with vibration. A good dealer will work on this until it is fixed. Under warranty.
'Knocking?' Do you mean the engine or something under the car? If you are using 91 or 93 octane (and you absolutely should be using one of those), there should be no engine knock whatsoever. If you mean under the car, then the knocking tells us something is wrong. Depending on the type of sound, it could be any number of things. But of course there should be no such knocking in a new car. I would think this has to be a warranty fix.
On the 'driverside door lock' thing, do you mean the door lock or the window lock? I can lock or unlock all four doors (simultaneously) from the driver's seat, and I can open or close all four windows (individually) from the driver's seat. And opening or closing those windows has no connection to whether the doors are locked or unlocked. If you have the Premium package, you even have the 'auto-up-and-down' feature on each of the four windows. Maybe I'm not understanding your exact situation? Help us out here.
The 'no loaner' policy is not customer-friendly. My dealer does not automatically give out loaners, but certainly has a person take me home and pick me up if the service will require more than a few hours. He has loaned me a 2000 Altima on a few occasions. With a new near-luxury flagship such as this '09 Maxima, I would hope most good dealers would do the honorable thing and give a loaner when the customer loses use of the car for warranty work.
I am sorry you are having a tough experience with your new '09 Maxima. Most folks here on the '09 board have had no trouble of significance. If you post again on this thread, let us know whether you have the S, SV, SV + Sport or SV + Premium. These four versions have different option packages. Maybe someone here can help us with some of this.
Old Oct 10, 2009 | 11:49 AM
  #162
NCSUpilot's Avatar
Any resolution on the clunking? I also have this issue (only when the temp is about 80 or so). Dealer couldn't find anything wrong although he did hear the noise. It happens when going over speed bumps really bad, banging/knocking while turning, and going over dips in the road. I hate noises and I don't think there should be any noises in the front suspension. Any thoughts from anyone on this issue?
Old Oct 10, 2009 | 01:20 PM
  #163
tpinsocal's Avatar
Originally Posted by Compusmurf
First issue I've discovered on my new car.
It's going to get a trip back to the dealership to check it out.
Front driver seat rocks back and forth about 1/2 inch. I KNOW that's not standard behavior!
Anyone else with an 09 see this?
I have the same problem but I don't think I'm moving 1/2"....frist time I felt it I kinda felt uneasy as the seat moved forward...they have a 99cent oil change at the local dealer so when I take it in Ill have them check out the seat...
did they fix yours yet?
Old Oct 10, 2009 | 07:59 PM
  #164
The 'rotational noise' or 'soft clunking' we have been discussing here is a one-time thing that happens around 17 MPH after the car has been parked a short while, then never happens again until the car has been parked again. It has no connection to speed bumps, turning, temperature or dips. Any clunking in those situations is almost surely a suspension problem of some sort, and the first place I would look is the front struts.
Old Oct 10, 2009 | 08:20 PM
  #165
Lanzz's Avatar
This rocking driver's seat is on my last dang nerve. I am taking it to the dealer next week, but I am not optimistic. Does anyone have an update on how their dealer solved this problem?
Old Oct 11, 2009 | 12:10 AM
  #166
michaelthepsycho's Avatar
The seat rocking is a minor DIY recall. There's a service packet I believe. I'm 99% sure because I read the PDF. I can't, however, point the the specific link. Sorry. There's this bracket that's supposed to be supplied.
Old Oct 30, 2009 | 09:17 AM
  #167
2young2retire's Avatar
I am sure someone else has posted this but just in case some have missed it. Issued September 15, 2009.
NTB09-092 2009 NISSAN MAXIMA; DRIVER’S SEAT BOTTOM SHIFTS SLIGHTLY
The driver’s seat bottom very slightly “rocks” and/or “shifts” back and forth when accelerating, braking, or when making a turn,
ACTION:
Replace the driver seat frame (adjuster assembly) with a new one.
Old Oct 30, 2009 | 09:32 AM
  #168
pearle's Avatar
I think this is for the passenger seat vibration. My dealer installed this in my car just a couple of days ago. The seat still vibrates like mad but it's not side to side vibration like before. It got rid of most of the rattle/noise from the seat so I'm content with it for now.
Old Oct 30, 2009 | 03:22 PM
  #169
hardcashsab31's Avatar
i didn`t want to start picking the car apart but i noticed my seat rocking also and i have 500 miles on the car.
Old Oct 30, 2009 | 04:03 PM
  #170
By 'rocking', I assume you mean the driver's seat? The passenger seat problem is more 'vibration' than it is 'rocking.'
Old Oct 30, 2009 | 04:24 PM
  #171
bmanbmv's Avatar
ACTION:
I tried to open this PDF file but it said I needed a nissan help login account. Anyother options you can suggest so I can open it. Thanks
Old Oct 30, 2009 | 08:20 PM
  #172
The best thing to do is to get an account with the nissanhelp site. It is free and you can download one TSB for recall each day. With a paid membership you have unlimited downloads. A very good site with lots of information.
Old Feb 21, 2010 | 05:36 PM
  #173
Mufassa's Avatar
NIssan posted a TSB for the 370Z http://www.the370z.com/370z-technica...at-corner.html
A very small group of 370z owners were having the same issue: http://www.the370z.com/nissan-370z-g...e-driving.html
Old Mar 5, 2010 | 04:40 PM
  #174
big nick's Avatar
i have the sport package also and mine does the same thing...I also have problems with my passenger window....had to get the motor replaced and then it went out again and BILL HOOD NISSAN in hammond la. said it was the motor and they had to order another one but THE VERY NEXT DAY!!!!!! IT STARTED WORKING AGAIN....MY TIRES ARE BALD...I BOUGHT THE CAR IN JUNE 2008 AND HAVE 30,000 MILES AND NEED 4 NEW TIRES ALREADY AND TO GET THE SAME BRIDGESTONE TIRE'S IT'S $380 A TIRE.....MY TRACTION LIGHT COMES ON ...MY PASSENGER AIR BAG LIGHT GOES OFF AND ON AND THE DEALERSHIP SAY'S THEY CAN'T FIGURE NONE OF IT OUT BUT WHEN I HIT 36,000 MILES THEY WILL FIGURE IT OUT JUST FINE.....
Old Mar 5, 2010 | 05:49 PM
  #175
dauntlessmax's Avatar
Maybe you have the avalible Summer Tires....
Old Mar 5, 2010 | 06:13 PM
  #176
smarty666's Avatar
Bridgestone's, especially sport and summer tires are known not to have the greatest treadlife on the market! if you want that your better with a Michelin!
Old Mar 6, 2010 | 02:13 AM
  #177
The lower profile a tire is, the lower mileage it generally gets. Despite the omnipresent eternal deniers of reality, 30K on 40 profile tires on a 3600 pound car with 290 HP is not that bad. I certainly do not expect to get much more than 30K with my tires.
As to the price, although there are a few exceptions, good tires for this car will generally cost betweem $200 to $400 each.
Old Mar 6, 2010 | 05:19 AM
  #178
LtLeary's Avatar
...I BOUGHT THE CAR IN JUNE 2008 AND HAVE 30,000 MILES AND NEED 4 NEW TIRES ALREADY AND TO GET THE SAME BRIDGESTONE TIRE'S IT'S $380 A TIRE......
I have 62,000 on the RSAs that came with my 09 (and still have 5/32s left) Will be replacing those at 4/32s. Not a big fan of the Goodyears but they do seem to be long lived.
Old Mar 6, 2010 | 10:48 AM
  #179
big nick's Avatar
To LtLeary....Do you have the 18' or 19' tire on your car???
Old Mar 6, 2010 | 11:12 AM
  #180
Your success may also be as a result of your long commute, where you are not doing as many sharp turns or acellerations or as much braking per mile or as the average driver. Also, doing so much expressway driving, you are probably more likely to maintain proper inflation, balance, alignment, etc than some drivers who do mostly city or suburban driving.
Having said that, I find my RSAs are wearing better than the Pirellis of my 5th gen and the Contis I had on my 6th gen. I am pleased, because I heard some unflattering things from the drivers of 6th gens using RSAs.
Old Mar 6, 2010 | 04:19 PM
  #181
XR GHOST's Avatar
I have a 2010 and its been about 3 months. And yea I noticed the ROCKING also but thought it was normal am about 170lbs. So I guess its a problem also my passenger side air bag is always off even when someone is setting there sometimes it will turn on.. Has anyone had this problem???
Old Mar 6, 2010 | 07:46 PM
  #182
jo_stv's Avatar
my 09 maxima has the rocking drivers seat. dont notice it as much, but am reminded of it every once in a while
Old Mar 7, 2010 | 12:40 AM
  #183
I've seen that problem mentioned here dozens of times. Nissan does indeed have an annoying situation with the passenger air bag. A weight of around 115 pounds (much more in some cars, less in others) is required before the car assumes a person is sitting in the passenger seat, hence turns on the airbag. But each car seems to have the cutoff weight at slightly different points. Of course the basic problem is having NO airbag protection for a person who is guilty of not weighing 115 or whatever trigger point weight that particular car's sensor is looking for.
Old Mar 7, 2010 | 04:42 AM
  #184
LtLeary's Avatar
18"
Old Mar 7, 2010 | 04:50 AM
  #185
LtLeary's Avatar
Agreed, add to that I've only engaged the "traction control" one time (after a brief rain where I purposely tried to gauge grip) and VDC was seen to flicker out of the corner of my eye while evading a deer. Although I've never been able to get the balance quite right with the RSAs (Slight but aggravating between 65 and 75.)
Old Apr 20, 2010 | 04:49 PM
  #186
Cubatobaco's Avatar
Ok, here is my first problem. I've searched this thread have not seen an answer to this. I have had my car 1 year already and the bluetooth has worked like a dream. So, here's the deal:
My phone (Blackberry Tour) connects with no problem, but for some reason when I try to answer my phone, whether on the steering wheel or on the screen, it doesn't answer. If I look at my phone, it says "transferring to handset". If I make a call, it connects for about 2 secs and then transfers to the handset. Has anyone had this problem? Thanks for any help you can provide!
Old Apr 15, 2011 | 04:47 PM
  #187
landerrich2@aol.com's Avatar
Originally Posted by Mick7
Under very light acceleration something similar happens on my car...right after the doors automatically lock. A little more pressure on the gas and it does not occur. I read somewhere it is sometimes the CVT belt..hope not!
I have this problem. What was the problem found and resoution?
Old Apr 16, 2011 | 05:56 PM
  #188
The '09 Maxima has a funny little noise just before or after the doors lock (around 17 MPH). Many folks have been bothered by this noise. But much discussion back when the 7th gen came out indicated that virtually all '09 Maximas make this little noise, which many drivers don't even notice.
With me, it always happens in the same place right after I have pulled away from the post office and turned down a side street and started to pick up speed while coasting. I was concerned until I found this was a common noise with this car.
We discused it here on the ORG for many months, and finally decided it might be something with the ABS system resetting. But it has never caused anyone to have a problem.
Old Apr 16, 2011 | 07:27 PM
  #189
magicaljerry's Avatar
i got the seat replaced
'09
now it makes popping noises LOL
oh well
Old Apr 16, 2011 | 11:33 PM
  #190
KingofNY's Avatar
I have a 2011... It came from the factory with the Homelink system broken. It doesn't do anything when I press the buttons or try to set/reset the system. Anyone else have this issue?
Old Jun 12, 2011 | 01:51 PM
  #191
MAX DADDY's Avatar
I have a slight rattle when going over hard bumps. I have had this issue in both my '10 Max and my new '11 Max. I think it might be the moon roof cover. Anybody with a dual panel experience the rattle? I have a single panel so that might help us determine the rattling we are all getting.
Old Nov 27, 2017 | 11:39 AM
  #192
broncobuddha's Avatar
Sorry to revive an old thread, but that's what searches turn up around here.
Apparently, the Nissan engineers have not fixed the rocking seat issue (Driver's side) as I have a new to me 2014 Maxima SV with 34k on it and the seat rocking is driving me crazy.
And it's not where the seat mounts to the floor. It feels like it's the center part of the seat, between the bolsters, etc...
Did anyone ever get a permanent fix from their dealer? I'm within the factory warranty and was thinking of trying to get it covered.
jmlee44
Oct 2, 2022 02:13 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Noela
Sep 26, 2015 08:22 AM
markevans999
Sep 10, 2015 04:29 PM
