Mirror Signal Lights
Old Apr 10, 2009 | 10:04 PM
ARosa1024's Avatar
Is there a way to change the color of the bulb inside the mirror signal lights?
Old Apr 11, 2009 | 10:09 PM
KillaKam's Avatar
Im sure that there is a way to. You probably just have to take off the plastic cover take out the circuit board or what ever the LED's are attached to and solder on a new pair of LED's which ever color your trying to use.
Old Apr 22, 2009 | 05:55 PM
Steve31Jo's Avatar
someone posted about this recently. hope that one helps.
Old Apr 22, 2009 | 06:54 PM
http://forums.maxima.org/7th-generat...ers-white.html
Old Apr 26, 2009 | 06:54 AM
navagating1998's Avatar
i bought a base model 09 Max, does anyone know if there is a way for me to add the signal mirrors to my ride?
thx!
Al
Old Apr 26, 2009 | 08:10 AM
KillaKam's Avatar
I believe that the newer models come with the same wiring harness so it should be plug and play. Thats how the New Altimas are. But i'm not 100% sure about the max
Old Apr 26, 2009 | 02:46 PM
thealliance43's Avatar
you can wire them up easily if you have an 09 maxima... just run a positive through your door under your dash to the BCM and tap into your turn signals... you can ground directly to your door...
fastcarny
Oct 6, 2015 10:42 AM
minsbang
Sep 11, 2015 08:48 PM
flu2000
Sep 8, 2015 02:23 PM
Maxima30
Sep 7, 2015 06:13 PM
