Sound Deadening for your 2009 Max - A tutorial of sorts
Old Jun 8, 2009 | 10:38 AM
22sandup's Avatar
Tools you will need:
10 mm Socket wrench
Small headed flat head screwed driver
Razor knife
Small roller
Drill with a phillips head piece
Great stuff
Threshold for pain
Not be queezy around blood.
Well I decided to sound deaden most of my 09' Maxima. I'm still in the works of doing so and will update when I can. So I'm here to tell you how to do things, what not to do and how not to screw up like I did. Lol.
I chose to go with Second skin deamplifier. Second Skin is by far the best sound deadner around. http://www.secondskinaudio.com/ I ordered 60 sf, but I need to order probably 20-30 more. When installing this I recommend wearing gloves, but here is the problem with that. Latex gloves are worthless as they stick to the backing of the sound deadening and make it more of a pain in the ****. Work gloves are also too bulky and you'll be taking them off all the time. I just had to tough it out and got about 50 cuts or so on my fingers, hands and wrists. Which was super.
Trunk Lid:
First I did the trunk lid. All you have to do is pop off the lid cover. It's had a bunch of clip ons and 2 rubber *****. The clips have four slots. You slip the screw driver in one of the slots and you pop up part of the clip then pull the rest out with your fingers. I went crazy on the lid and got almost every piece of metal on the lid. The lid feels 5-10 pounds heavier. I also did the license plate as well. Just cut out one piece to fit the whole plate and slap it on the back of the plate. You don't have to do the whole trunk lid, you can do only whats behind the carpeted lid piece and it will look neater. But I went crazy because I feel the lid is one part of the car that rattles the most. Great stuff would have came in hand here to seal up the cracks and hard to reach places, but I didn't think of that until I started the doors. Doh! Also you're going to think making holes for where the clips were is a good idea. Don't waste your time. You can the carpeted piece as a guide to where the holes are and just poke out the holes.
Rear doors:
I've only done one so far but they are both the same. There is a bolt behind the door handle. You can pop off the clip easily with a the flat head. The bolt is machined on and a pain in the ****, but will come off. Next is the light at the bottom. You can actually pull this off with your hands actually. And then you just unclip the wiring with the flat head. It's very simple. Next you pop off the arms rest with your hands. Also very easy. Disconnect the windows electric with a flat head. And you will see two phillips head screws. Then all its being heald on with is clips. Pull on the bottom of the door and it will pop off then up on the whole panel when all the clips are out and the whole panel will come off. The panel well still be attached at the back by 3 phillip head screws holding in the door handle. Unscrew these. The speaker is held in by 4 phillips head screws and they're 6 1/2 speakers. I modified the speaker pod and placed a new speaker in it. I made the mistake of covering the whole door. Only cover where the panel goes. And do not cover over the holes that hold the clips or around them or the door won't go back on. Inside the door is a bar that stops the window and then a grove all the way at the bottom. I sprayed great stuff below the bar and in the groove. The focused the deadening on the inside of the door.
Front Doors:
I learned my lesson with the rear doors. Front ones are a little more complicated to take off. Pop off the door light and disconnect. Pull up on the arm rest. You'll need a flat head to disconnect the front piece of the arm. Disconnect the window electrics with the flat head. The hand on the door has a screw behind it. So you'll need to pull off the carbon fiber piece with a the flat head. Start at the bottom. Remove the phillips head screw at the top and the door where the arm rest was. It has a bolt behind the handle just like in the rear door. The corner piece on the door and the door panel are two different pieces. Pop off the corner piece with your hands then when you pop the door off the clips push up on the whole door panel and it will come off. The panel well still be attached at the back by 3 phillip head screws holding in the door handle. Unscrew these. The front doors have 6x9 speakers held in by 4 phillips head screws. Unlike the rear doors there is a soild metal piece cover most of the door. Make sure to only lay the deadener around the trace out of the door piece and make sure to not cover the clip holes at all.
Old Jun 8, 2009 | 10:53 AM
22sandup's Avatar
Trunk aka pain in my ****:
The trunk was the worst. Pull out your maxima rug then you'll have a carboard carpeted piece. Its attached behind the seats. Good luck on getting this out. I had to just cut it out because its behind a impossible to get to bolt. You can't tell it's been cut out. Then there is a stryfome piece that is bascially worthless. Then the emergency tray and then the tire. I don't think I need to explain how to remove these. There are a **** load of clips in the trunk hold all the carpeting in. I managed to them all off. There are 4 seperate pieces. A plastic piece behind the license plate. You remove for clips. These clips are different. They have a little cut in the side of them. You put the flat in and pop it up. Takes some strength. When you get all four of these off just pull off and lift up. The carpeting has a couple of the same clips as well as the clips that are on the lid. Make sure you get all of these. There is also a carpeted piece under the rear speakers. A couple clips and it will come right off. I learned that Nissan has a complete hole in the bottom of the car for draining I assume. The vent is on the left side and the tire iron and jack are on the right. Do not cover the vent over! There are a lot of holes in the trunk. I filled the ones I knew that didn't seem to lead anywhere important with great stuff.
22sandup's Avatar
Well this is where I'm at right now as I'm out of deadener. I will update and answer any questions I can. Sorry if the pics aren't the best. It's my camera phone.
Old Jun 8, 2009 | 11:28 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Good job, dude. Just a note - this will not significantly deaden sound, this is quite a common misconception regarding sound deadening. Butyl mats such as this (or facsimile) only serve a very small part to reduce noise - they dampen, not deaden.
If you're really looking to deaden, you need a two-layer mat which serves to decouple frequencies, then absorb via closed-cell substrate.
Old Jun 8, 2009 | 11:30 AM
Oh, one other note - quick and easy way to solidify the trunk; spray great stuff in to the channels of the trunklid frame. If you don't have any open holes, drill them out, then cover with SSD.
Old Jun 8, 2009 | 11:38 AM
22sandup's Avatar
Yeah second skin sells the overkill stuff and spectrum which would make it damn near sound proof. But I just don't see how the doors would have gone back on with that much stuff on it. Like this was a tight fit. This will still make it sound a lot better than stock. And I have already notice the difference in the stock system.
Old Jun 8, 2009 | 01:09 PM
You will notice an immediate and excellent improvement in overall acoustics. I have 3 layers of SS, a layer of sludge, and LLP in some areas...and it's not sound proof. Quiet, but not sound proof. If you're looking for more deadening, you can use OKP on the skins of the door panel and LLP on the floor. GJ, though.
Old Jun 8, 2009 | 05:52 PM
Compusmurf's Avatar
Love my '09
I'm gonna add this in the FAQ thread just for your insanity!
Old Jun 8, 2009 | 07:28 PM
Good for FAQ, but hardly insane. This is pretty routine deadening for SQ purposes.
Old Jun 8, 2009 | 08:41 PM
Compusmurf's Avatar
Love my '09
Hey, 22sandup said it:
Threshold for pain
Plus he made his car look like a baked potato!!!!
I know the purpose and I can imagine the amount of work he put into it and the writeup!
The presentation of it, his use of a bit of humor and the great photos!!!! That's the insanity part!!!!!
It was meant as a compliment! But if he feels uncomfortable with my comment, I will remove it.
Last edited by Compusmurf; Jun 8, 2009 at 09:55 PM. Reason: Edited to quote the correct person. Sorry 22sandup
Old Jun 8, 2009 | 09:50 PM
22sandup's Avatar
Lol he's not the one who did it. I am. I think it is insanity. I should have taken a picture of all the paper cuts on my hands. Damn those hurt. Well worth it though.
Updates:
I ordered 30 more sf of second skin today.
Old Jun 8, 2009 | 09:53 PM
Compusmurf's Avatar
Love my '09
LOL, my bad. I misread and misquoted.
Will the real insane ones please stand up?
Yes, tho you had the disclaimer in there about blood, you should have shown ALL the results. (Including your hands) If you're ever in the Tampa area and want to bleed some more.......
Old Jun 8, 2009 | 09:55 PM
22sandup's Avatar
Anyone know what happens if you cover up the vent in the trunk?
That's where I live lol.
Old Jun 10, 2009 | 08:38 AM
bk2k3max's Avatar
Great job to go through and sacrifice your body and mind for this project, like Compu said, if you're ever down in Texas look me up!!
Old Jun 10, 2009 | 09:48 AM
Ok.
Old Jun 14, 2009 | 11:24 PM
22sandup's Avatar
Yeah there's a maxima on caraudio.com that went crazy like that. No way am I doing that.
Old Jun 15, 2009 | 12:14 AM
a33i30's Avatar
wow, that ones extreme. While its stripped out, might as well take it to a track.
Old Jun 15, 2009 | 12:20 AM
2LEET4U's Avatar
dam man, you spent $300+ on just sound deadener???
you must have a really kick *** system in there... and i hope you dont say Bose!
Old Jun 15, 2009 | 03:31 PM
22sandup's Avatar
System will be nice.
Old Jun 21, 2009 | 07:12 PM
Helo-Tech's Avatar
Holy crap!!!, I wish, I had the time to do that to mine. Nice work.
Old Jul 30, 2009 | 07:05 PM
tse54re's Avatar
How can I get deaden installed ?
There is no way in LLEH that I would be able to do any of the above
Are there car shops that do this professionally ? I would really love to have this done... Does it void the warranty?
What about anything to deaden the sound when the roof is opened ? I have the double sun roof and it sounds like a plane when the roof is opened.
Rob
Old Mar 23, 2010 | 01:47 PM
DraKhen99's Avatar
Quick question: did you have a chance to drive the car with just the trunk done? I notice some noise from the exhaust (as well as vibration) and think that some butyl mat like you used would quiet things down a few dB.
Old Aug 26, 2010 | 07:42 AM
gtr0manc3r's Avatar
rofl; damn this is some heavy stuff...kudos!
derekinthez
Nov 13, 2022 04:00 PM
9aj9
Apr 5, 2020 12:11 AM
TheMafia
Sep 4, 2015 08:26 AM
crazyespn
Sep 3, 2015 01:30 PM
