Knocking type noise...front end
Old Mar 22, 2011 | 01:20 PM
  #41
MooShoo's Avatar
I think the tinking noise you hear from the wheel well is the cotter pin bouncing around. If you take the front tires off you will see a pin that holds the rotor assembly in place as a security measure. If you crimp the cotter pin around the bolt and don't let it bounce around, the noise should go away. I had to do that and all is good.
Old Jun 25, 2012 | 06:14 AM
  #42
jkids's Avatar
I hear a similar noise in my 2011. Always happens exactly at 30mph. Sounds like a knock and I can feel in it the gas pedal, almost like something is engaging at 30pmh?
Old Mar 18, 2014 | 08:02 PM
  #43
the answer is's Avatar
front end noise when pulling off and turning
Originally Posted by REALM
I got the same thing, knock when pulling off from a stop. More noticeable if I'm pulling off and turning at the same time. Dealer couldn't reproduce it, obviously. They need a tab for this as it's embarassing. I've had a couple people ask me what it was.
what is it i have the same problem for about a month ago
Old Jun 24, 2015 | 10:56 AM
  #44
ralphtc86's Avatar
Front end rattle
Originally Posted by jixxxer
service guy said they couldnt hear the knocking noise; so they couldnt fix it. go figure!
I've had this issue with my Maxima, when I would start the car and it would idle you would hear a rattling noise from the front drivers side wheel, and even pulling away from a stop sign you could the noise, of course I drove the car with the technican, and the noise didn't happen, so he put the car back on the lift and started banging to fine where the rattle was coming from on my invoice it states "tech inspected, and clamped down loose components under vehicle to correct rattle noise." The rattle is now gone, so most likely if you have that rattle the undercarriage needs new clamps to resolve the issue. Hope this help guys!
JakeOfAllTrades
Oct 5, 2015 10:40 AM
MichMaxFan
Sep 30, 2015 09:18 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Sep 27, 2015 08:37 AM
