Amp shut off at high volume
Oct 16, 2010 | 07:29 PM
ok so today i got a new system audio pipe its a package there made for each other so nothing can be over powering or under powering. so when turn the volume up to like 18 it shuts off when i turn the volume back down the amp turns back on. i have no clue with the problem can be. is the amp defected or do i have a wire problem?
Oct 16, 2010 | 09:20 PM
What's all the equipment you have? What ohm load is the amp seeing?
Oct 16, 2010 | 10:32 PM
Quote: What's all the equipment you have? What ohm load is the amp seeing?
its a audio pipe 2 channel 1000watt 2ohm stereo stable, 4ohm mono stable
this is it
http://www.usaudios.com/products/Aud...f2027316160355
Oct 17, 2010 | 11:23 AM
what speakers do you have and are they wired in parallel or series? is the amp running in bridged mode or stereo? most likely your subs are wired wrong and the amp can't handle the low impedance and the amps cuts off.
Oct 17, 2010 | 11:50 AM
every thing is audio pipe the amp is in stereo mode each speaker is 2ohm the amp is 2ohm stereo stable and 4ohm mono stableit cant be low ohm impendence because I bought it as a package eveeything was made for each other
Oct 17, 2010 | 01:07 PM
Are you running a line output converter or anything like that? It sounds like you've got your gain on the amp or the converter too high and you're driving the amp into clipping.
Oct 17, 2010 | 01:31 PM
get a digital multimeter and set the gain on the amp
Oct 17, 2010 | 01:35 PM
here's info on setting the gain
http://mobile.jlaudio.com/support_pages.php?page_id=143
http://forum.realmofexcursion.com/am...al-2010-a.html
Oct 17, 2010 | 02:10 PM
thanks guys I will try this and see what happens and yes I have a line converter but it.doesnt have any controls
