Is there a way to only have the fogs on, and not the headlights?
Old Jan 16, 2011 | 10:45 AM
DiploMAX's Avatar
has anyone done this?
'10 sv.
Old Jan 16, 2011 | 10:54 AM
hero782's Avatar
rewire them to a switch
Old Jan 16, 2011 | 10:56 AM
DiploMAX's Avatar
Oh alright, thats what I figured.
Old Jan 16, 2011 | 11:06 AM
hero782's Avatar
yea i did it to my 6th gen, its fairly easy especially if your running HID fog lights
Old Jan 16, 2011 | 01:07 PM
maxxxxspeed's Avatar
U can just turn your running lights on and fogs should come on with those...
Old Jan 16, 2011 | 02:29 PM
Car Addict's Avatar
not in my max
Old Jan 16, 2011 | 03:03 PM
Kmoney's Avatar
i am the first member to do this mod.. you need to connect a relay to the foglight wire
Old Jan 16, 2011 | 05:01 PM
Originally Posted by Car Addict
not in my max
Really? Hmmm I think mine come on...
Old Jan 17, 2011 | 12:57 PM
Blittz's Avatar
Can they be wired/relayed to turn on/off auto with the headlights?
Old Jan 17, 2011 | 09:24 PM
hamzer11's Avatar
Kmoney, I must have missed you posting about it. Is it a simple clean job (lease car)? I might hit you up when the weather gets better to help me make this happen if it alright with you.
Old Jan 17, 2011 | 10:23 PM
Llfe's Avatar
i don't think he installed himself...
but can you take pics of the wiring and the relay or else kmoney can you provide pictures of the relay and the wiring?
Old Jan 18, 2011 | 05:11 PM
travis0385's Avatar
I havent checked in my car yet.... but I have done this mod to other cars... chrysler sebring and mazda 6.... you can usually do a jump in the fuse box. Pull out the fuse for the fog lights and find out which prong is coming from the voltage source and which is going to the fogs. Jump a wire from something that is on whenever your running lights are on like 'taillamps' and plug it into the prong from the fuse you just removed that you determined is going to the fogs. This should supply your fog light electrical wiring with juice even when the headlights are not on. Your regular fog light switch should control them still...
Again, I have not checked this out on my car yet so someone correct me if i'm wrong
Old Jan 20, 2011 | 06:51 AM
Stinkypete's Avatar
A how to with some photos would be great!
Old Jan 20, 2011 | 08:58 AM
I agree can you take some pics... king of confusing.
Old Jan 20, 2011 | 07:52 PM
shadowx3081's Avatar
I read something like this when I bought mycar and tried it but it did not work unless I did something wrong it doesn't work
Old Jan 21, 2011 | 02:01 PM
LakeShow's Avatar
I would love to have this done...
Old Jan 21, 2011 | 07:57 PM
Llfe's Avatar
i read through the other thread that dealt with fogs on with parking lights:
http://forums.maxima.org/7th-generat...fogs-only.html
i need flip2cho to respond to what his quick work around was
or else have logic05se to upload the diagram as well
i did this rewire in my 98 maxima using this exact tutorial: http://www.vqpower.com/v2/articles.php?article_id=31
but then i just found another how to for the 98 maxima that's easier from the same site:
http://www.vqpower.com/v2/articles.php?article_id=81
I think i'm gonna try out the new/easier way on my 09 because we have no separate corner light which was really really easy to pop out and work with using the 1st how to i did on my 98.
i just want to make sure that i'm not going to fry anything...going to use a voltmeter to test which power wires i need to tap into for the tail light...will this work?
Old Jan 23, 2011 | 02:28 PM
QTNAMAX's Avatar
Thanx for the info. This is a mod I thought should have been done from the factory.
Old Jan 23, 2011 | 02:50 PM
Llfe's Avatar
i couldn't wait and didn't want to cut the wires
i have lowbeam and fog light hid kits...so i just swapped around the h11 wires
oem switch:
headlight light to on: fog lights on
headlight light to on with fog switch light to on: fog lights and headlights on
i always drive with both of them on but now i can have the option to drive around with just the fogs...ghetto...but it works...and temporary until i can get it to work the correct way
Old Feb 25, 2011 | 09:17 AM
Esco90's Avatar
can it be done to an 09 maxima?
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
