Need help with LED install!!!
Old Jan 25, 2011 | 03:54 PM
Rking21's Avatar
Ok so part of the LED lights that I ordered came in yesterday, the rest are on backorder. Anyways, so I get them and since these are the metal coiled ones from autolumination install them in my license plate. So my girl comes home today and tells me that one of the lights is out. Im pissed i waited 2 weeks for these light and only 2 of them came in and now one blows out, wth! so i go out there and pull it out and try to put it back in. Then I notice the other one goes out, Im like WTF! so I grab the old lights and plug those in and no luck there either. I dont know what to do, can somebody help me out, please!!! I need these back asap!
[/IMG]
Old Jan 25, 2011 | 04:08 PM
Rking21's Avatar
i hate being a noob im gonna start with the fuses
Old Jan 25, 2011 | 04:25 PM
Rking21's Avatar
OK nevermind after locating both fuse boxes I have no idea how to procede??? Boone where u at bro? Thanks in advance!
Old Jan 25, 2011 | 07:25 PM
djdavebse's Avatar
the factory lights blew also?
Old Jan 26, 2011 | 05:28 AM
Rking21's Avatar
Naw I think a fuse did but I cuz I put the factory bulb back in and it didnt light up either, but I dont know which fuse to look for. I know where both panels are just dont know which one to fix? Im a super noob with all this.
Old Jan 26, 2011 | 06:38 AM
Kmoney's Avatar
check the fuse cover. it should tell you what each fuse are for
Old Jan 26, 2011 | 07:11 AM
djdavebse's Avatar
the fuse for the lights are 10 but look on the back of the panel and it will tell you and you have spare fuses you can use that
Old Jan 26, 2011 | 01:05 PM
BlackMax11's Avatar
deff sounds like a fuse problem when u went to put it back in again it shorted best bet change out the fuse and leave stock untill u get right watt bulbs
Old Jan 27, 2011 | 03:51 AM
Rking21's Avatar
I def thought I ordered the right bulbs they were T10 superstar bulbs with the heat sink super white 194 bulbs. So know the lights around the control panel r out as well, I'm heated right now I took off the fuse panel lid to see what fuse it was but I cannot tell! Gonna look at it again this morning then if i can't figure it out take it to the dealer, I'm pissed!
Old Jan 27, 2011 | 03:52 AM
Rking21's Avatar
Thanks for all ur guys' help tho I really appreciate it!
Old Jan 27, 2011 | 04:43 AM
Rking21's Avatar
just dont know which fuse to check clearence lamp, h/lamp, etc...im a super rookie with DIY stuff so i dont want to short the whole car, lol!
Old Jan 27, 2011 | 05:08 AM
Rking21's Avatar
I tried switching the clearance fuse with no luck, so Im going to the dealer at 1:30. I also flippin lost the spare fuse tryin to put it back in the space. Damn big hands cant fit in that lil compartment no its forever lost in the car somewhere since I couldnt see it i think it fell down into the trim panel, smh!!
Old Jan 27, 2011 | 08:16 AM
WHITE2K11SV's Avatar
Did you check the Tail Lamp fuse? I would just check that whole row to be sure. Good luck.
Old Jan 27, 2011 | 09:59 AM
Rking21's Avatar
Yea now it barely turned on I had to push the button like 5 times thus has become a nightmare
Old Jan 27, 2011 | 11:27 AM
Rking21's Avatar
So the bulbs I order from autolumination were apparently using to much juice cuzing the fuses to burn out so i hope the bulbs I order from v leds work better. This is the description for the bulbs I purchased which were apparently to much!
Introducing the New & Improved
Outfitted with the latest Super High-Flux low profile Leds
Designed especially for gauges, and applications requiring a large uniform field of bright light
Note: These have the all metal heat sinks for constant-on applications to reduce heat related failures
Only 9mm diameter x 24mm overall
194 Superstar Bulbs With Metal Heat Sink
Blue
Super White
Red
Amber
Green
UV
Order 194 Superstar Bulbs (shown above): $6.99 ea.
Choose Color
Super White Blue Red Amber Green UV
Choose Type
194
***Click Here to add a tracking number to your order***
doctorpullit
Jul 20, 2019 09:31 PM
MaxLife17
Jun 27, 2019 01:37 PM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
jds22
Sep 4, 2015 01:52 PM
