Lock Chirp Buzzer.
Old Mar 1, 2011 | 07:47 AM
steevo's Avatar
Lock Chirp Buzzer.
Does anyone know how to make chirp sound work when you use the thumb button locks on the door? My 2008 Altima works exactly as described here. I am thinking maybe the 2011 Max no longer makes a sound when you use the door lock pad on the car? They call it a Buzzer, but its more like a chirp to me. Its not the horn.
Locking doors
1. Move the shift selector to the “P” position.
Place the ignition switch in the LOCK posi-
tion. Make sure the Intelligent Key is not left
in the vehicle.
2. Close all doors.
3. Push any door handle request switch  1
while carrying the Intelligent Key with you.
4. All doors and the trunk will lock.
5. The hazard warning lights flash twice and
the outside buzzer sounds twice.
Old Mar 1, 2011 | 08:53 AM
trix_05's Avatar
Thats how my Max works (2009)
Old Mar 1, 2011 | 08:57 AM
hamzer11's Avatar
I don't think I get a buzz or a sound when I lock using the buttons on the door handles. Never knew there was any sound except the horn with the remote locking.
Old Mar 1, 2011 | 09:04 AM
bluelion's Avatar
i get the "beep beep" when i use button on door handle. i got " honk" when i use key fob.
Old Mar 1, 2011 | 09:37 AM
mrodenberg0124's Avatar
What he said.
Old Mar 1, 2011 | 10:24 AM
Dubl-A's Avatar
Mine sometimes creates an alarm of chirps (Maybe 10 chirps). Anyone have the same issue?
Old Mar 1, 2011 | 10:48 AM
steevo's Avatar
I think that means you left the keys in the center console, or the lights are on...
Old Mar 1, 2011 | 11:38 AM
Car Addict's Avatar
I disabled the honk. Annoying to me. Especially walking in the house late at night.
Old Mar 1, 2011 | 11:58 AM
djdavebse's Avatar
i have a factory alarm and when i press the button it honks twice im not sure how to disable it
Old Mar 1, 2011 | 12:10 PM
bluelion's Avatar
i tend to use the door handle button when i get home late.....the beeps aren't as loud as the honk....
Old Mar 1, 2011 | 12:36 PM
bkmaximaa's Avatar
well if you hold lock and unlock on the remote the lights will flash and the car is in silent mode....same way to turn it off
Old Mar 1, 2011 | 12:52 PM
steevo's Avatar
Yea the beeps are perfect. Just loud enough to know all the doors locked. I am starting to think they removed it for 2011?? Anyone with a 2011 have the buzzer chirps?
Old Mar 1, 2011 | 02:10 PM
Dubl-A's Avatar
Ah, maybe it was my wifes key fob left in her purse behind the seat. DUH lol
Old Mar 2, 2011 | 04:29 AM
Juggernaut23's Avatar
How about the exact location of this buzzer? Maybe we can use it for other things like lock/unolock confirmations with aftermarket alarms and such instead of those annoying standard alarm sirens that no one even pays attention to anymore.
Old Mar 4, 2011 | 05:16 AM
steevo's Avatar
Exclamation SOLVED -- Sticky??
Ok I found the problem. I also had another issue that may help some people. The Climate Control system was always off when I started the car, and set to 75 degrees, rather than being the way I last used it. When I took delivery of the car I found a tag under the seat labeled "IMPORTANT!". It seems this tag must have fell off the mirror.
It turns our that 2011 Maxima's made after December of 2010 have been equipped with an Extended Storage Switch. This switch can be found in the interior fuse panel. Switch is "out" and a number of vehicle functions are disabled, or have limited operation. Notably, the Intelligent Key Buzzer, the Auto AC Unit, and some mirror functionality.
Push the switch "in" and it engages a fuse which restores full functionality. Pull it back out for Inventory Condition extended storage mode.
Hopefully this helps out a few people.
Steve
Old Mar 4, 2011 | 05:20 AM
Rich007007's Avatar
Nice find! Definitely sticky worthy imho.
Old Mar 4, 2011 | 07:05 PM
lightonthehill's Avatar
Steve
I have been driving sixty-four years (and learning to drive for a few years before that), and I don't remember ever encountering anything quite like this. I feel Nissan should either have the switch in the 'operational' mode as the car leaves the factory, or have dealers acutely aware that this switch MUST be engaged if the car is to be test-driven or sold. There is no excuse for the extended storage switch to be set unless the car is to be moved into extended storage.
Thanks for this VERY interesting info. I feel the dealer sort of 'owes you one' on this.
Old Mar 5, 2011 | 06:05 AM
09Maxima_Sam's Avatar
Just curious. I only have a 2009, but wondering if it affects things like radio and seat presets as well?
Old Mar 5, 2011 | 06:49 AM
steevo's Avatar
TSB NTB10-124b .. EXTENDED STORAGE SWITCH AND BCM TRANSIT MODE
All about the switch. It has a table that shows what functions are disabled or limited and on which vehicles.
Whats funny is on the cars it also disables the Consult DDL.
Old Mar 5, 2011 | 07:13 AM
Got a link????
Old Mar 5, 2011 | 01:58 PM
Also interesting that this switch was added only to Maximas built within the last two months. A little unusual to see this type change in the exact middle of a model year.
Old Mar 26, 2011 | 09:22 PM
italy932003's Avatar
Where is the fuse panel?
Steve
Can you please tell me where the panel is and what the "switch" looks like. Bought my Maxima today.
Old Mar 27, 2011 | 06:05 AM
steevo's Avatar
When you are sitting in the drivers seat, it is in front of your left knee.
Old Mar 27, 2011 | 07:09 AM
Thanks, Steve!
Old Mar 27, 2011 | 01:24 PM
Schneid's Avatar
I would love to have the beep beep from the key fob as opposed to having to touch the button on the door handle. The horn sound from the key fob is just annoying, especially when I am coning home late at night from work.
Old Mar 27, 2011 | 01:32 PM
Maximum Drive's Avatar
I totally agree with Schneid. What happens in "silent mode"? Does it not do anything when you lock at all? Or does it do a chirp instead of a horn honk when you lock from the fob?
Old Mar 27, 2011 | 01:51 PM
Schneid's Avatar
I've tried it and it only silences the horn still no beep beep.
Old Oct 15, 2012 | 04:54 PM
brookz's Avatar
Thank you so much!
enabled the "chirp" on my 2012
James92SE
142
Jan 2, 2024 09:23 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
ajahearn
Sep 19, 2015 03:03 PM
johnaschon
Sep 14, 2015 04:29 PM
