rear window wont roll down in 09 maxima
Old Jul 24, 2011 | 06:34 PM
2009maxima sv-sport's Avatar
well im not sure why but my rear window wont roll down in 09 maxima from the drivers door but works from the rear switch and its only on one side suck the the warrentry for the maxima just ran out last month any ideas.
Old Jul 24, 2011 | 07:00 PM
michael454rs's Avatar
the driver switches are bad probably
Old Jul 24, 2011 | 07:24 PM
any idea if this is a common problem cause i hardly ever use my switch to control the rears.
Old Jul 24, 2011 | 10:00 PM
lightonthehill's Avatar
I haven't seen exactly this problem before here on the 7th gen board.
During hot weather, I crack all four windows about four inches using the driver's door switches every time I park the car (except when parking in my garage). I would guess I have done that an average of three times a day between mid-April and late October for the last two and a half summers. So far, I have never had any kind of problem.
For those who may wonder if cracking the windows four inches lets rain in, I have rain guards that prevent rain from reaching that four inch gap.
My first guess would be the same as michael454rs; driver's door switch.
Old Jul 25, 2011 | 09:26 PM
LtLeary's Avatar
While I haven't experienced this in my 09, I did once experience this in my old 300M. Toggling between down and up a few times (ok a dozen) seemed to free it up. Unlike Light, I didn't then and don't have rain guards on my Max but had the issue you described after rain soaked the switches once.
Old Aug 14, 2011 | 02:51 PM
Lame i now have the same problem my rear windows wont roll up or down from the driver but work when using the rear switches. Tried looking for a master switch at thr junkyards but the bastards wanted 100 dollar for the part. This was for my 03 looke at some for an 02 and 01 but are different. Mine was the same as 04 and on.
Old Aug 15, 2011 | 07:24 AM
AbleRiot's Avatar
Common Issue? Disconnect Battery?
I had this happen to my then '07 Altima - I could roll it down with driver's panel but not up - but rear passenger control could bring it back up
here is the link to that thread were others seem to have had this issue as well
http://www.nissanclub.com/forums/200...ow-switch.html
and this:
http://www.nissanclub.com/forums/200...t-roll-up.html
From the look of things, it's not as simple as resetting the up/down on the auto windows but more of a main-switch issue. Others seemed to have luck with disconnecting the battery. I don't remember but I think my issue resolved itself - one day it just worked
Old Jan 22, 2012 | 01:23 PM
themark1's Avatar
my windows are stuck down and it is snowing outside. Couldnt get care started so I was chacking fuses under hood when I leaned on key in pocket rolling all my windows down.
******PLEASE HELP**********************************
Help I have a similar problem. Yellow key light on. Cant turn on the accessory. Cant roll up windows (hard key doesn't work). I live in Alaska. 100 MILES FROM THE DEALER.
I've changed the car battery, the primary fob battery, and have tried the back up fob.
My brake lights do work.
I've noticed that the steering wheel lock is not engaging though.
All the while, though, the yellow light stays on while I'm seated in the car with either or both keys.
Yes I've tried to sit key in key boot. without any changes. Not even sure why they put that in the car.
And Yes, I've checked all the fuses.
Old Dec 6, 2020 | 03:35 PM
English's Avatar
Master switch replacement
I have an 09 maxima, my passenger window was not working from my master switch on the drivers side but,it would work on the passenger side itself I changed the master switch,both the passenger and drivers windows work perfectly but now none of my rear windows,does not work at all I have power in the doors because I checked. if the doors lock and unlock from the new master switch and it does but neither window work from the master nor the doors themselves and ideas?
fastcarny
May 18, 2020 10:40 AM
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
kjm900r
Aug 5, 2015 07:14 AM
RealityCheck
Aug 5, 2015 06:18 AM
