Footwell Lights
Old Mar 7, 2012 | 06:58 PM
Erbalyst's Avatar
Footwell Lights
Can someone tell me if there is a way to remove/replace the footwell lights with minimal effort? I have a 11 Max SV and i am interested in replacing the stock and with LED blues.
Old Mar 7, 2012 | 09:18 PM
morteljc's Avatar
just get under each side and go read for it... thats how i did mine...
Old Mar 8, 2012 | 12:43 PM
Erbalyst's Avatar
Thanks. I can grab it but I am not sure how to pull them out of the housing.
Old Mar 8, 2012 | 01:18 PM
turkeeslapper's Avatar
You need to twist them. They will pop right out.
Old Mar 9, 2012 | 12:06 AM
morteljc's Avatar
did yours twist? mine just pulled out... literally... no twisting... i think it has a 194 socket...
the actual housing is also easily removable... but i did not mess with it as my hands are too big that it was a bit hard for me to put a tiny LED bulb back in...
Old Mar 9, 2012 | 04:28 AM
gbech's Avatar
194 is correct and they pull straight out
Old Mar 9, 2012 | 10:59 AM
Buzzooka Joe's Avatar
Is there a way to make the footwell lights turn on while driving? They are only on when the door is open.
Old Mar 9, 2012 | 12:43 PM
eljoker's Avatar
they are easy man, you dont even have to pull them out of the panel, (if you want too, you can just twist btw) all i did was pull the bulb out and insert the new one, just dont squeeze or they pop and cut you. Rocking 20 SMD leds in each one.
Old Mar 9, 2012 | 03:17 PM
Ghozt's Avatar
yeah you could rewire them so they're connected to a relay that you add to the car. might void some electrical warranties but you could independently control them
Old Mar 9, 2012 | 11:17 PM
Erbalyst's Avatar
Thanks guys......I was able to twist the housing out and swap the stocks.
Old Mar 10, 2012 | 06:36 PM
Jam_Roc's Avatar
Drivers side out (not even 2 months old) trying to replace the buld but its really wedged in, going try some pliers on it next.
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
