Engine knock perhaps elevation dependent...
Old Mar 19, 2012 | 08:03 PM
CorollaULEV's Avatar
Being here in NE AZ near the four corners, there's lots of elevation changes if you travel any distance. So, after being in Pheonix for 4 days, I didn't notice any engine knock except a few times. It was very faint at that. When climbing from Pheonix (~1100 ft elevation) all the way back up to Flagstaff (7000 ft elevation), the knock returned as loud as ever. In Kayenta, where I live, is 5700 ft (no difference from Flagstaff in terms of noise).
So, temperature wasn't a factor, either. It was 65-75ºF in Pheonix and was the same temperature when I left from Ktown.
Just throwing it out there that this might be an elevation related issue.
Late,
Trav
Old Mar 19, 2012 | 10:34 PM
2young2retire's Avatar
The '10 Maximas were not required to run premium fuel as were the '09's and the only difference maybe in the timing. The knock sensor does a good job of compensating for lower octane fuel but it may not be able to handle the job at high altitudes. If you are running regular fuel then throw in a tank of 93 octane stuff and see if it continues. If it stops then you may want to check with the dealer to see if there is a problem with the sensor. Good luck.
ballerchris510
Sep 23, 2015 08:46 PM
ac max 92
Sep 17, 2015 07:35 AM
ballerchris510
Sep 11, 2015 05:29 PM
