Looking for a BBK? I have a solution..
Old Apr 7, 2012 | 07:58 AM
eljoker's Avatar
370z Stock brakes are direct bolt ons for the 7th gen max, and 6th gen SS brake lines will also work.
I got this from a member on a different forum, he has pictures but I need his permission before I post them.
http://www.nissanraceshop.com/produc...ono-410111ea1b
So far I have only found them individually, looking for a place that sells them as a set with rotors and pads.
Old Apr 7, 2012 | 02:27 PM
vr4z06gt's Avatar
Does it fit with the back spacing of the wheels on the 18" rims? I know this is an issue when upgrading to the real big brake kits, from Wilwood for example. Sure the 370Z/G37 kits will bolt right up on the Maxima, but they will not clear a stock wheel when you go to put that back on.
Old Apr 7, 2012 | 03:09 PM
eljoker's Avatar
Not sure yet, waiting on confirmation.
Old Apr 7, 2012 | 07:51 PM
Jam_Roc's Avatar
i want!
Old Apr 7, 2012 | 08:01 PM
MiDiablo's Avatar
BBK > stock wheels. So who cares abt that? Lol. If you can throw bread on a BBK, you need aftermarket wheels anyways. Or at a minimum 19" OEM wheels.
Old Apr 7, 2012 | 08:37 PM
esco115's Avatar
To the ones asking if the 370Z BBK fits the stock 18s the answer is NO! Even wouldn't fit with the stock maxima 19's, unless spacers are used.
Old Apr 7, 2012 | 10:04 PM
longisland09maxima's Avatar
I have teh 19" 370z Rays so im assuming the 370z BBK would fit?????????
Old Apr 7, 2012 | 10:09 PM
MiDiablo's Avatar
If you find a set or 2, LMK, because I've been searching at different 350/370Z/G35/G/37 forums w/no success yet! And yes your 370Z wheels will clear your BBK, too.
Old Apr 7, 2012 | 10:11 PM
eljoker's Avatar
They will fit with stock Rays 19s from the Z.
Old Apr 8, 2012 | 06:54 PM
STARR's Avatar
http://forums.maxima.org/7th-generat...10-brakes.html
this is on my list of mods to do, according to this previous thread 15mm spacers and the BBK should fit with the stock 18/19 wheels, which Im happy to hear cause Im not a fan of aftermarket wheels, if I do change wheels then rays19
Old Apr 8, 2012 | 07:26 PM
esco115's Avatar
^ the 18's wont fit the 370z BBK... hense why the 370z with brembos comes with 19's.
Old Apr 9, 2012 | 09:44 AM
GM_Traitor3.5VQ's Avatar
Actually the stock 18" 370Z base wheels will fit over the Sport model's BBK. I have two friends with the 40th anniversary Akebono's on their base 370's. Now, the stock Maxima 18's won't fit over the same BBK due to the different offset. Stock SV Sport 19's will fit over the Akebono BBK as long as you're running a 10-15mm wheel spacer on the front.
Old Apr 9, 2012 | 12:56 PM
esco115's Avatar
^ ok I thought you were refering to the max 18s, it just wont clear the caliper period. unless your doing custom work.
Not sure how ur friend got the 18s to fit as its tight as hell with the 19s on it. Unless they custom fitted the calipers to fit the stock 12" rotors on the base. I know with the 14" rotors and brembos 18's are too small.
Old Apr 9, 2012 | 01:37 PM
Sorry, I should have clarified a bit better. You can definitely put the 14" rotor and Akebono 4-pot system on the front of the A35 with the stock 19's and a 15mm spacer and it'll fit just fine. The overall diameter isn't the issue, its the clearance between the back of the wheel spokes and the face of the larger caliper that poses the problem. With a 15mm spacer, you'll have about 3mm of clearance between the 4-pot caliper and the rim. More than enough space
Old Apr 9, 2012 | 06:32 PM
MiDiablo's Avatar
What exactly is Akebono? From what I saw they only offered like OEM stuff, no? I guess, technically, the Brembos/etc are 'OEM', though. I just put all new brakes on the car, but dying to do wheels/coilovers/BBK right now :-)
Old Apr 9, 2012 | 07:17 PM
esco115's Avatar
yes that I know, just as the back brakes fits just fine on the A35 as well...
Old Apr 9, 2012 | 07:44 PM
eljoker's Avatar
Nissan doesn't house Brembo on the Zs/Gs any more, the use Akebono.
Old Apr 10, 2012 | 04:30 AM
Ghozt's Avatar
the debate was never about if they fit the A35. it's if they fit stock rims without spacers, and the answer is no due to the spokes of the wheel.
Old Apr 10, 2012 | 05:57 AM
Exactly. Nissan only uses Brembo's on the GTR now. Last model year Z's and G's to use the Brembo's were back in 2008 on the Rev-up 3.5's. Nissan switched to Akebono in 2009 for the new 370/G37 sport models.
Old Apr 30, 2012 | 01:24 PM
MaximaSE96's Avatar
Maxima Owner
i was just thinking about 350z brembos as an upgrade...I wonder if they work
Old Apr 30, 2012 | 02:36 PM
eljoker's Avatar
The G37 Sports brakes (Akebono) will also work and this guy is selling a set.
http://www.myg37.com/forums/private-...no-brakes.html
Old May 1, 2012 | 04:24 AM
MaximaSE96's Avatar
Maxima Owner
not a bad price....i was on ebat looking for Brembos and people want anywhere from 1600-3000....for that i can buy a stillen or Brembo GT kit...wtf lol
Old May 1, 2012 | 10:03 AM
eljoker's Avatar
You can get it even cheaper if you look and there are a few vendors that sell them in what ever color you want and with any decal.
Old Aug 23, 2012 | 08:28 PM
bryansuavo's Avatar
bringing this back... who can post a DIY? or all the parts needed to make this happen?
Apr 16, 2020 05:15 AM
Quickgtp
Apr 13, 2017 03:30 PM
maxfever1987
Nov 19, 2016 08:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
IceY2K1
47
Oct 9, 2007 09:00 PM
