Need solid answer for interior LED bulbs
Old May 19, 2012 | 08:44 AM
gofastgt's Avatar
I did a search and found this thread
http://forums.maxima.org/7th-generat...b-listing.html
but it seems like there still was not a solid answer as to whether or not all of the interior bulbs were the same or not. The link above shows a mix of bulbs (see below), which is backed up by the sylvania website, but some of you said that they are all the same. On a 2009 SV does anyone know for sure?
This is from the thread above:
Glove box
158
Map light
175
Dome light
175
Step/Courtesy light
194
Trunk/Cargo area
158
Old May 19, 2012 | 08:49 AM
Ghozt's Avatar
on the inside i think everything is the same except for the visors and glove box (glove box could be the same too i just dont remember). the rest inside though are the same
Old May 19, 2012 | 09:09 AM
gofastgt's Avatar
If that's true I wonder why these mixed numbers are out there. I guess I'll just have to pull them all and compare them...
Are all of the plastic covers just the pry-off type for the most part? Any link to a site that will show how to get at the bulbs? I'm especially wondering about the dome lights since you push on the plastic part to turn the light on/off.
Old May 19, 2012 | 09:11 AM
Jam_Roc's Avatar
I put 194s everywhere except the visor and the glove box. I did the visor but havent reach the glove box. Yeah, 194s in the trunk too.
Old May 19, 2012 | 09:26 AM
gofastgt's Avatar
What kind did you go with?
I know the sylvania web site said that in 2009 they put a few different bulbs in the cars for that year, and to check the stock bulb before ordering one. I'll prob just do that for all of them at this point.
Old May 19, 2012 | 02:00 PM
Jam_Roc's Avatar
AGT 194 168 2825 5-SMD White High Power LED Car Lights Bulb
Old May 19, 2012 | 02:56 PM
gofastgt's Avatar
What do all of those numbers mean in the title? 194 168 2825 5?
I like these, but don't know if they'll work since those numbers are different:
5K WHITE HIGH POWER LED LIGHT BULBS 194 168 158 2821 | 1 PAIR
Old May 19, 2012 | 09:53 PM
Nemo7's Avatar
The different number just shows you the compatibility of the lights
these are the one i bought for my inside except for my glove box and my visor
http://store.ijdmtoy.com/Nissan-Maxi...san_df_06c.htm
i have these in my license plate lights
http://www.v-leds.com/6K-WHITE-4-LED...87987-1-2.html
Old May 19, 2012 | 11:52 PM
morteljc's Avatar
everything i used had a 194 socket... it is the same as the T10... except for your vanity lights... it just depends on how you want it...
as long it has the number "194" or "T10" it should work... these numbers, i think, refer to the socket type...
there are some things to consider... angle, degree of coverage, length or width of the entire bulb, and of course color...
Old May 20, 2012 | 08:09 AM
gofastgt's Avatar
That's interesting that different numbers can fit the same socket. I ordered all the same bulbs and then got 4 vanity bulbs. I'll just have to see if they all fit. From what you are all saying, they should.
Thanks for all the info!
Old May 20, 2012 | 11:40 AM
Jam_Roc's Avatar
The 5-SMD is the amount of diodes on the bulb.
Old May 20, 2012 | 11:54 AM
Papies01's Avatar
Everything was the same in my 2010
Old May 20, 2012 | 12:58 PM
gofastgt's Avatar
Cool. I'm hoping they are all the same. I'll report back once they are all installed. I can't believe there's only one bulb in the trunk... hopefully the 5 LED will be enough light back there. On that same note, I'm hoping I don't look like these stupid Honda Civic's running around with my license plate lights way too bright. Trial and error...
Old May 20, 2012 | 06:23 PM
Nemo7's Avatar
as long as you get white you shouldn't look ricey...
and for the trunk you should get this!
http://racinglineperformance.com/sho...&idcategory=31
Old May 20, 2012 | 06:27 PM
gofastgt's Avatar
Yup, I ordered white so hopefully it looks ok.
wow, that trunk is LIT UP!! LOL. If the little bulb I bought isn't enough I'll definitely keep that in mind, thank you!
Old May 21, 2012 | 06:16 PM
GoodFella218's Avatar
I ordered 2 LED interior lights from DDM just to test them out but they are pretty noticeably different colors. Can somebody reccomend the best site to purchase the interior bulbs? Don't want to waste any more time..Thanks.
Old May 23, 2012 | 08:03 PM
gofastgt's Avatar
Installed everything tonight and love them! Lights the interior up like its the middle of the day! LOL To be honest, they are a little too blue for my taste, not much, but just enough to the point that I wish I got some that are a little whiter. Just my thoughts.
So they were definitely all the same size, so that was good.
For the license plate bulbs on the trunk lid, a tip is to pull the lid down enough so you can see the outside of the car and reach up and under as you're trying to put them back in... helps to watch what you're doing.
The glovebox was a piece of cake. I found out that the glove box light doesn't come on when you open the glove box... it comes on with the parking lights... what sense does that make???
AaronL
Aug 8, 2020 10:31 AM
Fbana41
Aug 29, 2016 12:18 PM
Noela
Sep 26, 2015 08:22 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
meccanj98
Sep 17, 2015 08:28 AM
