SwitchBack From V-LEDS
Old May 23, 2012 | 05:12 PM
silver7thgen's Avatar
Started a new Thread because I am looking for a fast answer, I am going to Get the V-LEDS "CK" Switch Back Turn Signals And The Little Wedge Light in the corner of the headlight and 3 OHM Resistors Because I already have LED in the Rear Signals. So those with Experience in this purchase Can you give some highlight on if I/We shall need anything more. And also might be good for those who are going to get this in the new future. Thanks.
Old May 23, 2012 | 05:31 PM
Ghozt's Avatar
get some tap-in connectors, you can buy em from v-leds or get em from radioshack. they make adding the resistors to your factory wiring really easy and if you need to take em back off they dont leave mangled looking wiring just a tiny cut around the wire
Old May 23, 2012 | 06:03 PM
Thanks Ghozt. So that's all I need then? If so Ima press the purchase tab
Old May 23, 2012 | 11:26 PM
Ghozt's Avatar
I also grabbed some high-temp 3M adhesive strips so I could just stick the resistor onto a piece of metal. Make sure it gets placed somewhere away from plastic/wires it will get hot and melt stuff. If you have trouble installing the resistor and getting it to work, make sure you're attaching one end to a ground wire and other end to the turn signal wire. For some reason on my car the turn signal wire was a different color wire on each headlight and I figured it out just by trying different wires (?)
Old May 24, 2012 | 06:29 AM
rtitan's Avatar
The resistors come with the tap in connectors, everything Ghozt mentioned.
Old May 24, 2012 | 02:31 PM
Thanks for the info Appreciate it.
Ghozt
20
Mar 7, 2016 09:58 PM
Ghozt
46
Oct 19, 2012 01:25 AM
6.5affiliate
Jan 6, 2011 06:25 AM
Deep007
Sep 25, 2010 01:51 PM
