Headlight and Tail Light Question on a 2009
Old Jun 1, 2012 | 03:27 PM
mideastbeast's Avatar
Currently I have a 2009 Maxima and I was wondering if anyone has swapped out the headlights for the new smoked headlights that come on the 2011 and 2012. I also wanted to know if anyone has changed out the tail lights to the new smoked ones that come on the 2012. Personally I like the new smoked look and I was wondering if anyone has done the swap and if there were any problems.
Thanks for the input.
MEB
Old Jun 1, 2012 | 06:04 PM
20_Maxima_10's Avatar
MEB
all plug n play. just search. i put the 2012 tails in my 2010
Old Jun 1, 2012 | 06:56 PM
http://forums.maxima.org/7th-generat...my-2010-a.html
My Car
Old Jun 2, 2012 | 02:37 PM
Jbling700's Avatar
I didn't do any swap but I took off both my headlights for Kmoney to customize and my tail lights to smoke. The headlights were easy to remove. Pretty straight forward. There is a DIY on here. For the tail lights, just hit it with a rubber mallet. Don't use any flat screw drivers. You'll end up breaking it. There is also a DIY on this too. Just to a little bit of research on here and you'll find what you need.
Old Jun 8, 2012 | 06:10 PM
rcjunkie's Avatar
2009 Maxima - Left HID headlight is out
Speaking of headlights. My left Xenon HID light went out. Dealer said it was a bulb so I ordered two replacement Philips bulbs. Performed the install myself to save $225, uplugged power, removed plastic parts and pop-clips to get behind the headlight to replace bulb.
Replaced the bulb. With power connected, I turned on headlights...left side still DEAD, right side good. Knowing that the right side bulb is good. I borrowed the right side HID bulb and plugged it into the left side headlight and no go, still DEAD.
I installed the replacement bulb that was on the left headlight onto the right headlight and it came up nice and bright, GOOD
I know all my bulbs are good. Where else should I check? Fuses? Does the 09 Max have separate fuses for left and right headlights? Thanks!
Old Jun 8, 2012 | 06:47 PM
Sounds like a fuse or ballast. Check the fuses under the hood to see if they are still good, if so then you have a bad ballast.
Now back to our regularly schedule thread topic......
vingodine
45
May 21, 2016 12:46 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
rtirbany
Sep 8, 2015 11:46 AM
KristyKarina
Aug 23, 2015 09:53 AM
220k+ A32
Aug 17, 2015 03:57 PM
