Wheel Spacers/Adapters 7th Gen
Old Jul 1, 2012 | 08:12 PM
jspagna's Avatar
Did a search but couldn't find anything with reference with the 7th Gen Max. Just picked up a 2012 SV. Stock 18" wheels with stock oem ride hieght. Was size spacers cab I go with front and back without having any rubbing issues.
On my daughters 2003 Maz with the Titanium Edition and stock ride heights I'm running 5mm in front and 15mm in the rear. Not sure what to go with in the 7th gen.
Thanks in advance for all the help.
Old Jul 1, 2012 | 08:16 PM
Ghozt's Avatar
with the stock 19's i ran 20mm front 25mm rear (ichiba v2's) and it looked great
Old Jul 2, 2012 | 06:27 AM
Stelianos's Avatar
I know this has been asked to death but did your spacers ever come loose?
Old Jul 2, 2012 | 12:56 PM
Ghozt's Avatar
nah. just install properly (torque to 75 ft/lbs both the spacers lugs and your wheel lugs and check and re-tighten after 500 miles). too tight and you may warp the spacers, too loose and obviously things may come off
only horror stories ive heard about spacers were using cheap spacers or improperly installing them
Old Jul 2, 2012 | 02:23 PM
jspagna's Avatar
^^^^ Yes you need to re-torque at 500 miles. Personally I go for at least 80-90 ft/lbs. That is what I did on my daughter Max and everything ok so far.
Old Jul 2, 2012 | 03:31 PM
Ghozt's Avatar
i contacted ichiba and they mentioned 75 ft/lbs for their v2 spacers. just follow whatever the manufacturer recommends and you're good
Old Jul 2, 2012 | 05:26 PM
jspagna's Avatar
^^^ Good to know. Thanks
Old Jul 2, 2012 | 09:58 PM
dr_2010SV's Avatar
What's the deal? Never hear any mention of the type one vs. the type two spacers here?
I've done the longer wheel studs when bracket racing (years ago).
It wasn't because of the use of spacers. It was a NHRA safety rule requirement to visually indicate the studs were long enough and fully engage through the lug nuts.
I would have no problem pressing in longer wheel studs to accommodate the added spacer thickness required to properly offset the wheels.
I was just wondering if there is/or if anyone had an issue in doing this with the 7th gen Max?
The type two spacers are not particularly appealing to me for this or any car I would drive on a daily basis. Simple is most often the best.
Old Jul 3, 2012 | 06:59 AM
Ghozt's Avatar
Type I are the thinner widths, they have longer studs that need to be installed. the Type II have their own studs and bolt-on to the wheel hub. ive ran both without issues. the Type II's I had for over 8 months until i switched wheels, my Type I's I've had for a few months now
Old Jul 6, 2012 | 07:01 PM
dr_2010SV's Avatar
Thanks Ghozt.
After I lower the car I'll look at the spacer widths that will work for me.
The whole (10) studs per wheel of the type 2 has always thrown a bit of a curve in my less is simpler is better mentality.
Taking time to care for the proper torque obviously goes a long way in the sucess with the type 2 spacer set-up.
I'll continue to study this more!
Old Sep 16, 2012 | 01:06 PM
tmo7177's Avatar
When you had the type 2 spacers..you checked the torque after 500 miles and then how often did you check?
Old Sep 16, 2012 | 06:55 PM
dr_2010SV's Avatar
Actually I've only have had them on for about 400 miles or so now.
I did recheck the torque last week and they were still at spec.
No issues so far and I don't anticipate any down the road.
Old Sep 16, 2012 | 07:57 PM
Dieseldan's Avatar
i check mine every 4000 miles after the 500 retourque
Old Sep 26, 2012 | 11:38 AM
BoldMax's Avatar
Ghozt Thank you for the info. I am looking to get the same wheel set as you however in chrome. ANY advice will help!!
1. Where do I start to look for the 370z wheels...Ebay?
2. Recommend any Chrome shops?
3. any brand in wheels spacers?
Old Sep 26, 2012 | 12:32 PM
PSU09MAXIMA's Avatar
1. there or here on the classified or the other maxima site MY7thgen.org, also craigslist
2. Not sure
3. ichiba V2 seems to be what most go with here and I havent heard anything but good things about them
Old Sep 26, 2012 | 05:12 PM
Ghozt's Avatar
troll around the 370z forums or start hanging out with some Z car clubs they pop up every now and then. i got mine on a sick deal from a friend, had to get new tires but i wanted Hankooks anyway.
no idea on the chrome shops.
Eibach and Ichiba both make great wheel spacers, whatever you get make sure they have hubcentric rings otherwise **** will vibrate to all hell
Old Apr 9, 2018 | 06:32 PM
Nissanfinatic's Avatar
Ok, guys, I know nothing about cars I went on the Ichiba site, and I see different sizes I feel like my front wheel need to come out a little more I am running z wheels with 245/35/19. I feel like the front need to be out a little more, and it will be perfect. Any suggestions.
Maxima_Joe
Nov 25, 2015 08:19 AM
Maxima_Joe
Oct 15, 2015 08:01 PM
03VQMAX
Sep 25, 2015 04:19 PM
tnewbs
Aug 28, 2015 10:15 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
