Soft paint
Old Sep 1, 2012 | 06:41 PM
Stelianos's Avatar
Soft paint
This might be the dumbest post ever but here goes, there actually is an upside to our super soft clearcoat. It makes it very easy for paint correction. I realize if it wasn't soft it would scratch so easy but at least it's easy to repair. I had a good scrape on the front bumper and a quick wet sand and polish and it's good as new. Just my two cents.
Old Sep 1, 2012 | 09:07 PM
Dieseldan's Avatar
i agree the max is no the softest paint i have been woring on my highlander is BUTTER sft only needed a polishing pad a 106ff.
But I recently changed LSPs and only used a gray pad and 85rd and it removed some light swirls which is great when only using such a light abrasive
Old Sep 1, 2012 | 10:13 PM
dr_2010SV's Avatar
Yes true, but good luck with those damn chips as they are coming.
Like acne they won't respond to the same treatment.
Old Sep 2, 2012 | 05:03 AM
Stelianos's Avatar
Very valid point, I've been lucky with chips SO far.
Old Sep 2, 2012 | 07:09 AM
Jbling700's Avatar
The only way to prevent rock chips is to install a clear bra on the bumper. Pricey but worth it
Old Sep 2, 2012 | 08:29 AM
zoemayne's Avatar
leather bra is good too if you like the look. But about the soft paint, for the long run I think it will be negative. Did the previous gens have this paint?
Old Sep 2, 2012 | 08:33 AM
T_Behr904's Avatar
Old Sep 2, 2012 | 08:20 PM
Dieseldan's Avatar
if i owned the car i would do a clear bra but lease so no option
i use dr color chip and wet sand and it looks damn good unless u r right on it. BUT i dont drive highway alot so it has not been a huge problem for me
Old Sep 3, 2012 | 10:24 AM
MONTE 01&97 SE's Avatar
Since the 5th gen in 2000 it has had this horrible water based paint, a lot of 5th through 7th gens that I see have battered front ends. 2nd,3rd and 4th gens paint hold up much better
Old Sep 3, 2012 | 03:09 PM
Stelianos's Avatar
I wonder what it would cost to spray an additional harder clearcoat over the factory paint before it gets beat up.
Old Sep 3, 2012 | 06:10 PM
Very good ?
Old Sep 3, 2012 | 08:36 PM
Dieseldan's Avatar
not hard assuming your body is straight and no scratches deeper than CC
all u have to do is lightly sand CC and lay over I assume
BUT proper detailing technique will help eliminate unwanted blemishes
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
TKHanson
Nov 24, 2018 01:39 AM
Luigi623
Sep 21, 2015 01:42 PM
