Steering wheel problem. Motor grinding and stuttering.
Old Sep 24, 2012 | 04:38 PM
eljoker's Avatar
Mine just started acting up, I have 37k and no extended warranty. FML. Can I disable it all together? I assume the TSB ont help and I still gotta pay for it. I have an 09 SV sport without nav or tech.
Old Sep 24, 2012 | 04:52 PM
Ghozt's Avatar
yeah disable the auto tilt in the settings in comfort menu. i had mine replaced and then disabled it shortly after cause its cool to watch but other than that is really excessive use of those motors
Old Sep 24, 2012 | 05:00 PM
eljoker's Avatar
What comfort menu? I have the amber screen. Thanks ghost.
Old Sep 24, 2012 | 05:53 PM
silberma's Avatar
Perhaps if enough of these steering column motors failed during warranty Nissan will realize that it needs to build a more a robust system to protect its bottom line and reputation.
PS I had several Honda Accords and drove them to about 200,000 miles with basically routin maintainance. Hope my 2012 Maxima comes close to that.
Old Sep 24, 2012 | 06:00 PM
eljoker's Avatar
If I could just locate the right fuse I'd pull it. I don't need the feature right now.
Old Sep 25, 2012 | 06:51 AM
dr_2010SV's Avatar
It's in the manual 4-13/4-14. From the statement in 3-31 I believe you need the Nav option to disable it.
Old Sep 28, 2012 | 08:23 AM
Chicken Daddy's Avatar
I just had my tilt motor replaced at no cost through my extended warranty. The service advisor told me that they installed an updated motor.
Old Sep 28, 2012 | 08:39 AM
PalmettoFellow's Avatar
I really like the auto-tilt wheel and sliding seat feature of the Maxima. It's hard for me to get in smoothely when the seat and wheel are at my preferred setting. Opening the cabin up makes it easier to get in and out.
I have noticed that when I start my car and let it warm up, it's harder to get in and out as the car moves to the drive setting. My workaround was to program memory setting 2 as a wide open tilt and seat slide. This way, even with the car running, I can quickly open up the cabin and step out.
Old Sep 28, 2012 | 09:03 AM
dr_2010SV's Avatar
^I agree. I'm 6'2" and I need all the space I can get when entering/exiting this car, especially after lowering it.
I contiplated disabling it but then thought this is a feature I wanted with this car, disabling it now (when it's work fine) just so it won't break later is not going to happen.
If it goes out later I'll just pay to get it fixed.
Old Sep 28, 2012 | 09:31 AM
eljoker's Avatar
I found the part for $214 new and I had a buddy pull up the Alldata instructions. I can do this my self in an hour tops. And nissan wants to charge $1100, F that. To the bat cave!
Old Sep 28, 2012 | 10:33 AM
20_Maxima_10's Avatar
yeah buddy! bout to lubricate mine today when I swap the LEDs on the steering wheel.
Old Sep 28, 2012 | 12:31 PM
eljoker's Avatar
All data is King, I might make a DIY with a buddy of mine that works at the dealer ship.
Old Sep 28, 2012 | 12:39 PM
I am just curious. How much of the $1100 was parts and how much was labor? Is the $214 part OEM, or 3rd party?
Old Sep 28, 2012 | 12:52 PM
eljoker's Avatar
Oem, I was quoted $400 somthing for the part by nissan and the rest was labor, said it would take a few hours.
I found the part here, its # 9.
http://www.everythingnissan.com/Item...668-824922.htm
Old Sep 29, 2012 | 11:38 AM
LtLeary's Avatar
I had both motors replaced in 11 on my 09 at the dealer. $703 out the door. (tilt and in-out are separate motors/assys.) 1100 seems very high.
trasmadean
Feb 1, 2017 08:20 PM
vingodine
45
May 21, 2016 12:46 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
tnewbs
Aug 28, 2015 10:15 AM
Flores94
Aug 11, 2015 12:53 PM
