Help engine over heating !
Old Dec 5, 2012 | 02:56 PM
gotfunk?'s Avatar
So like two weeks ago I was parked outside texting and noticed the temperature gauge on the dash going up quickly... As soon as I started driving it went down. Figured it was low coolant. Next day got some and topped it off. No problems since. But today I was parked and it happened again !!! Any ideas ?
Old Dec 5, 2012 | 05:38 PM
GSB Maxima's Avatar
Verify that your fans are working for start, makes sense that when you're not moving it starts heating up.
Old Dec 5, 2012 | 05:56 PM
Eddie 70's Avatar
Wow! That sucks. This is the second on here that has been mentioned to over heat. I checked my coolant level a couple of days after I picked mine up because of that thread. Reading this about another car will have me checking again just to be sure.
Did you top it off in the radiator? What was the level like in the overflow bottle.
Old Dec 5, 2012 | 06:01 PM
lightonthehill's Avatar
Yes, if your engine is off, there is no coolant circulating through the engine, and the electric fans are the only way the engine can cool itself, and that manner of cooling is not enough to keep the internal temps down in the engine.
This is why, especially in summer, we sometimes see antifreeze/coolant running from underneath a vehicle that was recently parked. That is why we have the coolant overflow tank on modern vehicles.
When the coolant gets too hot (expands) to be contained in the radiator, it moves to the overflow tank. As the engine cools back down, the coolant is drawn back into the radiator from the overflow tank. If all systems are working properly, the engine is always hottest shortly after being turned off on a warm day.
Old Dec 5, 2012 | 10:10 PM
gotfunk?'s Avatar
I just topped it off in the reserve. Could that be the problem?... I'm going to take it to my mechanic tomorrow. Maybe it's the fan that broke. I'm at 68,000 miles by the way.
Old Dec 5, 2012 | 10:12 PM
gotfunk?'s Avatar
Is replacing the fan expensive
Old Dec 5, 2012 | 11:20 PM
MaximaGuido09c's Avatar
It'll cost ya..but if you are under warranty..you will be alright.
Thank you for reminding me, I have to change my coolant..I haven't done this before..is it simple or should I just spend the $26 at Good Year?
Old Dec 6, 2012 | 06:03 AM
gotfunk?'s Avatar
Checked my coolant and it was low again ! Within two weeks ! ... Yea I just bought Normal any vehicle 50/50 coolant
Old Dec 6, 2012 | 06:53 AM
PSU09MAXIMA's Avatar
I'd take it back to the dealer sounds like you may have a leak
Old Dec 6, 2012 | 08:08 AM
jax690's Avatar
I recently posted an overheating issue to this forum. My issue was a cracked radiator side tank (not the overflow container) which was a defect from the factory. I would definitely take it to the dealer as it sounds like a leak.
Old Dec 6, 2012 | 09:55 AM
gotfunk?'s Avatar
I'm no longer on factory warranty. The dealer is just going to rape me. Rather take it to a close friend who's a mechanic
Old Dec 6, 2012 | 10:16 AM
You sound like me..that is the funniest response I have heard in awhile. I would recommend taking it to a mechanic who is a friend over nissan and their horrible customer service. They generally do more harm than good.
Old Dec 6, 2012 | 01:48 PM
gotfunk?'s Avatar
Lol for real. I think it's just a hose that needs replacing. No big deal (phew!)
Old Dec 6, 2012 | 02:00 PM
MONTE 01&97 SE's Avatar
26 is cheap for a coolant drain and fill done at a business, doing it yourself you will save a little bit. For 26 I would let them do it.
Old Dec 7, 2012 | 06:47 AM
gotfunk?'s Avatar
Took it to my mechanic turns out I need to replace the thermostat gasket, said it'd cost me about 180:/ damn. With new springs, shocks and struts, 400 for back tires, 180 for transmission drain and fill... New brakes yesterday... This car is getting to be expensive !
Old Dec 7, 2012 | 06:59 AM
gotfunk?'s Avatar
Kinda bothers me cause I took a c class to 140,000 with virtually ZERO problems. Not to mention I put regular in it for years and never ever got an oil change on time.. As soon as I bought the maxima with 36 k the power window went out, the reverse mirror tilt broke and so did the steering wheel tilt motor ,.. Lol sorry just frustrated
Old Dec 7, 2012 | 10:00 AM
My family has had a lot of Mercedes over the year..all different types..I have always experienced issues with them eventually. Guess you got lucky on that C Class! My steering wheel tilt motor just broke..fml
Old Dec 7, 2012 | 10:11 AM
Did you get it turned off before the motor went?
Old Dec 7, 2012 | 10:38 AM
eesjunin's Avatar
Thats not a good behavior to be proud off ( talking about the benzo)... I had a c class as well and took care of that baby, at 250K miles you could still eat of the engine.
Old Dec 7, 2012 | 10:39 AM
Yes..It barely works now..so I managed to put it at a position I feel comfortable in..and then turned it off in the Comfort/Convenience Settings..Thank God!
captchaos
Mar 15, 2016 12:18 PM
seesole
Sep 14, 2015 12:38 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
DayHeyZeus
Sep 11, 2015 03:17 PM
bennuss
Sep 11, 2015 05:55 AM
