BC Coilover spring rate
Squeaking Noise after BC Coilover install
I have the BC Coilovers on my 2011 SV and the ride height is perfect. I even like the stiffer ride quality. However since install I have noticed what I will call a "torchered metal" sound coming from the front when I am turning the steering wheel. I usually hear this when backing out of my garage. Any ideas on what may be causing this. Or has anyone had the same issue. I had my coilovers professionally installed at Butler Tire in Atl, Ga.
Squeaking noise
Who at BC are you working with? I wonder if they would send out a replacement set ahead of repairing mine. It's rather costly to take them off the car send them in and then put them back on the car. If they are defective they should be replaced.
I've been talking to Sam who has been extremely helpful. I only took minr off and sent them back bc i was having other issues. You could ask for replacement bearings and he may ask you to send the old ones back once the new ones are on. Or he may just send them to you without hassle since they are probably cheap enough.
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
