Led light for glovebox
Old Mar 25, 2013 | 07:17 PM
lmalatino116's Avatar
Changed the glovebox light and had to take everything apart to do so
http://www.cardomain.com/ride/401933...-nissan-maxima
Attached Thumbnails Led light for glovebox-image-2383350758.jpg   Led light for glovebox-image-2501210478.jpg
Old Mar 25, 2013 | 09:58 PM
silver7thgen's Avatar
Wow looks like a lot of work by the pics. I just took off the plastic piece.
Old Mar 26, 2013 | 12:11 AM
99NightRiderMAX's Avatar
Yeah I just took off the plastic cover too and turned it. Came out fairly easy.
Old Mar 26, 2013 | 12:18 AM
Serpent's Avatar
Does your car have over 15k miles? Shoulda picked up a cabin air filter for $10 and put it in while you had that apart.
Old Mar 26, 2013 | 05:19 AM
Jig9798's Avatar
You don't need to do anything to the glove box to change the micro filter. It's actually accessible from the passenger side footwell. It's tuck up behind the center console.
Old Mar 26, 2013 | 05:58 AM
Jig9798's Avatar
Where did you get the LED for the glove box ?
Old Mar 26, 2013 | 09:18 AM
I tried to pull the plastic I think I cracked it alittle will most likely order a new one just because I know it's like that.
My car only has 3000 miles so have not even changed the oil yet
I purchased the LED from EBAY on a budget always try to get any add on's at the best price:
http://www.ebay.com/itm/150911469748...84.m1439.l2649
I will say that they lost my first delivery and I received 2 LED's instead of 1 worked out pretty good
Old Jun 18, 2013 | 08:42 PM
Boslax6123's Avatar
What a PITFA....got my trunk and gb from carid and the rest from ijdmtoy....very happy with ijdmtoy - easy to install, worked right away.
As for the set from carid, the trunk bulb was too thick and didn't fit correctly. I couldn't put the plastic cap back over it. Yes my '12 has a cover over the trunk light.
Now the glovebox really requires you to take the entire thing apart to properly install it. What a tease it was nice to first see a plastic cover that seemed to good to be true and pop off, nope cracked the plastic, but eventually it came off. Then I proceeded to push the female piece through trying to secure the LED.....ugh!
Writing this I'm hoping needle nose pliers will be able to grab it as to avoid having to remove the whole glovebox.....
Ok done venting lol
Old Jun 19, 2013 | 06:30 AM
Ghozt's Avatar
Should be pretty easy also to re-wire the little switch in the glove-box that turns the light on to the interior lighting so you don't need to have the damn headlights on to see in your glove box.
Old Jun 19, 2013 | 07:08 AM
Boslax6123's Avatar
Good idea Ghozt. I noticed that right away....
MaxLife17
Jun 27, 2019 01:37 PM
Maxie40
Sep 14, 2015 11:28 AM
minsbang
Sep 11, 2015 08:48 PM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
