Self-install Fog light kit
I just finished up putting in HIDs to my Maxima S and was looking at fog lights. Since the "S" version doesn't even have fog lights, will there be connectors down there at all for fog lights?
Any recommendations on fog light kits? I would need projectors since I don't have anything there right now.
Courtesyparts.com has the kit for the stock fog lights which are not projectors. If you want projectors, they will be aftermarket fogs and may require wiring your own switch (if you wanted one).
I ordered my 6k HID Projector/Halo Fogs from Protuninglab.com which use a housing that bolts right on... however, there is a bolt on the top of the fog light (or the black placeholder thing if it's an S) that is basically impossible to remove because it's so close to the crash bar. I ended up just removing the entire front bumper to do my install (which I recommend because it's always nice to have extra room to work), but I suppose you could probably just partially remove it like some people do for their headlights.
*Edit*
Kmoney beat me to it, but yea I forgot to mention they're pre-wired for the OEM ones.
*Edit*
Yea it came with the wiring relay switch and cables i got it from ebay @ docholiday
http://item.mobileweb.ebay.com/viewi...id=23415140156
This is the best way to go, stay away from the cheap plastic ebay ones.
http://www.courtesyparts.com/nissan-...300_8455_8679&
umnitza
09-01-2015 01:03 PM
