Looking to replace just the mufflers
I'm pretty happy with the performance of my maxima (R2C, Y-pipe), but i want a little sound. I was thinking of replacing just the mufflers w/ universal Magnaflows. Does anyone the size that would replace the factory ones? Has anyone done this before?
I'm thinking center/offset?
I was looking for the size of the in/out and to see if it center/offset etc. Whats the largest muffler we can fit under there if I go universal 14", 18"? I'd just stick on the stock tips.
Lol, those are the exact ones I was looking at, they make the exact sound I'm looking for... what worries me is that he doesn't have a y-pipe in the clip and I do.. So I assume they'd be much louder with one?
I don't have a good answer for your size question but MF makes a couple of universal mufflers with tips that look pretty good. Part numbers are 14827 and 14829.
Sound wise nothing major but there is a bit of difference. At idle it's subtle but to me it sounds more "pipey" for lack of a better term compared to the stock exhaust.
Yeah not sure if the MF muffler will be a direct fit as the stock max muffler has an offset inlet I believe.
My plan (if I ever get around to it) is to use the MF with integrated tip and just have the mufler shop bend new pipes and add a new attach flange at the Y so you would essentially have a axel back system that would bolt on in place of the stock set-up.
That way if you ever wanted to go back to the stock exhaust it would be as easy as a couple of bolts.
Edit: Yes the stock pipe is 2.25 if I remember correctly.
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
