Just got the Bully Dog GT
Old May 31, 2013 | 05:12 PM
Fundem's Avatar
Ok, I went for it...
Now I followed the instructions perfect. It gave me options to set my rev limiter, and top speed... But how do I adjust timing? It walked me through those 2
Old May 31, 2013 | 05:57 PM
Fundem's Avatar
Ok, I'm the guy that didn't scroll down, lol
But at the timing adjustment page, it won't go either up or down
Old May 31, 2013 | 07:07 PM
Jam_Roc's Avatar
Lets hear the good news!
Old May 31, 2013 | 08:49 PM
Fundem's Avatar
How do you guys get it to work? Or else I'm returning it
Old May 31, 2013 | 08:57 PM
dr_2010SV's Avatar
So BD doesn't have a customer service number you can call for assistance?
Old May 31, 2013 | 10:54 PM
Fundem's Avatar
They do but I got it after hours
Old May 31, 2013 | 11:18 PM
Fundem's Avatar
I got it up 2 deg but it idles at 8-900 in D?? Idles that right?
Old Jun 1, 2013 | 09:24 PM
WiSeGuY187's Avatar
I believe you need to run a idle air relearn after you advance timing, idk if the BD will do that or u may need to get it done with a consult3 machine
Also make sure u do a review on it with ur max bc the BD doesnt have a good name for our cars
So lets hear ur take with ur "tun3" if u wanna call it that and performence changes if any
Old Jun 1, 2013 | 11:21 PM
Fundem's Avatar
It all went well, BD has a feature to manage the idle that I over looked... This thing is sick... I guess they did some serious upgrades cause I can control everything perfect now and I love it... Especially since I have like 2 years of warranty left so i can always bring it back to stock.
Old Jun 2, 2013 | 08:50 AM
dmcmahan12's Avatar
Can you tell the difference on the butt dyno?
Old Jun 2, 2013 | 10:14 AM
WiSeGuY187's Avatar
X2 and which tune did you choose premium tune or regular ?
Old Jun 2, 2013 | 02:10 PM
Fundem's Avatar
I chose premium. With everything turned up it its a totally different car. Today on +4 deg I messing around with a friend and his 2013 S4 and I was right with him the whole time. I am VERY surprised at all the people who think the BD is a waste. The $389 for what it did to my car with the option to return back to stock was more than worth it. Hands down the best performance mod I have to date. Maybe it's the updated software or that my car is 2011, but I can't see why people hate on it so much. I have the R2C, y-pipe, and just replacement magnaflow mufflers.
Old Aug 7, 2013 | 06:18 PM
dikingx's Avatar
Bully
Fundem so u say it's worth it then I have a 2010 and need some extra torque and hp btw what part of li u from
Old Aug 7, 2013 | 07:30 PM
trailer54's Avatar
That's great news! I was dabbling the idea of one, but I think a Uprev tune would be more beneficial!! I'm glad to read it's doing well!!
Old Aug 9, 2013 | 07:26 AM
Jodius Tha Warrior's Avatar
You can feel the difference on the butt dyno. At +4 timing, you can really pull some G forces... Although, the timing advance doesn't always stick.
It's not a real tune... But I think its pretty good without spending too much money on a more sophisticated tune and dynotime.
Old Aug 9, 2013 | 05:34 PM
bk2k3max's Avatar
Well, I'm not sure for one which BD Tuner you have. When I originally purchased the Power Pup (They retired this model), it was a total waste and you absolutely felt no differences in power or anywhere else. There were numerous complaints to which BD ignored and did nothing with and now for all of the people who still have their BD PP Unit and has had the upgrade from Nissan to their car's brain the BD PP Unit will no longer work with the car's new programming.
If you plug in the old BD PP Unit you will get a response that tells you to contact BD but they will not assist you unless you have one of their newer tuners and there is no download support for the old PP Unit.
Old Aug 9, 2013 | 09:33 PM
dr_2010SV's Avatar
I admit I will talk out of my "butt dyno" sometimes.
So your 0-60 and 1/4 mile track times are what....?
Old Aug 10, 2013 | 08:46 AM
Envymynissan's Avatar
Post a link please. To see what you bought... Does it clear if you unplug the battery to reset the ECU?
Old Aug 10, 2013 | 10:05 AM
dcpatters's Avatar
Initial base timing is dependent on Coolant temperature. This is the parameter updated via the GT "special vehicle options". When coolant is too cold or hot, timing changes. But the timing increase with the BD GT does remain. I never seen it not.
With two different monitoring devices, Torque Pro and BD GT, I confirmed a .2 tenths reduction in 0-60 and the same held for 1/4 mile times. Trap speed was 99 mph. All was done the same day, same road, weather etc. This included returning to stock, re-flashing the premium tune, etc.
Moreover, I found increasing timing from the factory 14-15 degrees initial, made the car slower. Let me explain.
With the Torque Pro and a plug-in, Knock Detector, there were cases of spark knock and corrections in timing reduction (1-2 degrees) from the factory ECU; only in the higher mid-range at WOT. With or without the BD GT installed, initial timing is the same as factory, however, I'm sure the timing tables have been tweaked for more aggressive timing, hence the spark knock when adding more timing. Note: I can only run 91 octane, so others with 93 may not have this problem. Just because there's no audible knock, doesn't necessarily mean none exist. Likewise, the STFT and LTFT trim banks 1 and 2 look better than the factory tune as well.
In the end, with a few tools, you can see there are subtle modifications in the tune which help the car. The only drawback, and to me what prevents the Maxima from being quicker off the line, is the WOT restriction. For this reason, I just purchased the UpRev Osiris Tuner edition and moving on from the BD GT. I'll report updates later, in another thread.
Old Aug 13, 2013 | 05:53 AM
From my experience, the +2 timing sticks. The +4 timing does not stick as the Nissan ECU has a way to override it. I'm not a automotive computer expert, I'm just saying. The turbo-like pull from a +4 timing doesn't stay past a couple days. That's why most people who put the GT on their cars here do only +2.
As for WOT, do you know of any fixes for that? I once read about something called Sprint Booster. I wondered before if that is even worthwhile and if it eliminates WOT.
Old Aug 13, 2013 | 11:39 AM
dcpatters's Avatar
Correct, good point. +4 degrees is beyond the 17 degrees base timing for the Nissan ECU. Regarding Sprint Booster, I think it just remaps throttle A,B,C tables. Basically, I think it just makes the throttle input very sensitive. When I had my Evo X MR, members debated on getting one. Do they make one for the Maxima?
Old Aug 13, 2013 | 12:54 PM
dmcmahan12's Avatar
Great information dcpatters and let use know about the UpRev after you install and try it.
Old Aug 13, 2013 | 01:09 PM
Ghozt's Avatar
I wouldn't bother with the Uprev tune unless you have all your performance parts added to the car; otherwise you'll be re-tuning later
Old Aug 13, 2013 | 06:54 PM
dcpatters's Avatar
I'm done; drop-in filter and cat-back exhaust. Tried an intake, too loud for me. No BOP and spacers either. Could care less about that.
Old Aug 17, 2013 | 07:09 AM
They do make one for the 7th gen maxima. This site has it for $290. Don't know if I wanna spend so much on that.
http://www.sprintboostersales.com/de...ima&engine=Gas
I wonder how the Bully Dog advanced timing and the Sprint Booster combined effect would be on the driving experience. Like.... +4 timing AND the most aggressive setting on the Sprint Booster.
Old Aug 17, 2013 | 02:03 PM
dcpatters's Avatar
30-Day Money back guarantee. Try it. Like mentioned already, +2 will put you at 17 degrees, no more is possible.
Old Aug 17, 2013 | 06:37 PM
Ghozt's Avatar
if you only have a cat-back exhaust, why would you bother with a tune or anything else? its basically operating at factory specs
Old Sep 5, 2013 | 02:24 PM
dcpatters's Avatar
Hey Dan. Apologies for the late reply. The factory tune can be cleaned up, a little leaner throughout and more timing in some areas for a little more power. So far, the car is much better feeling, snappier acceleration.
The key or most important reason for tuning, is the throttle control and torque management. I've been logging, and can clearly see the ECU starts closing the throttle at higher speeds, approximately ~85 MPH. Moreover, there is a dip at lower speeds right @ WOT. I have the graphs so it's not something I'm assuming or guessing.
Anyway, once this is addressed, the car should feel much better.
Old Sep 11, 2013 | 09:06 AM
mlowe's Avatar
I haven't looked at the Maxima's ECU at all, so Im not sure of its function. Take this with a grain of salt until I can look at the ECU a little.
I read the above saying that +4 degrees of timing is eventually reset due to the BD increasing timing over the ECU's base timing more than 17 degrees. In theory, this would easily occur as almost all ECU's monitor and self correct their functions over time. That's the nature of piggybacks and that's another reason I love stand alone ECU's.
If someone wanted +4 degrees of timing all the time, it can be accomplished by clamping the signal the ECU receives the motors timing from. This can be done with an inline resistor. Find out the voltage that the ECU receives for +17 degrees and match that with a resistor of the same voltage. The ECU would never see the true timing.
With that said, use extreme care as you can then inadvertently set the timing to anything and fry the motor.....
Old Sep 12, 2013 | 04:52 AM
Fry the motor... No thanks. Lol.
I keep the timing at +2 everyday now. The Maxima has a nice pep to it's step.
What I do like about the BullyDog is how it lets me see over 30mpg on the highway. I can tell that my gas tank has more mileage now than before when I didn't have the tuner installed.
Old Sep 12, 2013 | 08:55 PM
Hydroshocked's Avatar
What is your average speed on highway?
Old Sep 13, 2013 | 05:37 AM
Anywhere from 65 to 75.
Old Sep 13, 2013 | 10:16 AM
mlowe's Avatar
I would love to get 30mpg
carid
Sep 17, 2015 05:00 AM
PSU09MAXIMA
Aug 28, 2015 12:47 PM
Wolvee
Aug 11, 2015 12:24 PM
