GPS Mount - what & where
Old Aug 25, 2013 | 03:13 PM
Max2013's Avatar
I would appreciate some info on how any of you have mounted a Garmin. Mount type, placement, and wire routing would be very helpful. Any photos would be great! Thanks---
Old Aug 25, 2013 | 05:03 PM
funnyman82's Avatar
I use my Garmin once in a while on longer trips but I actually suction it to the centre screen in the car because I don't use need to see it that often.. But another thing that I have that may be more useful is the mount by mountek which will fit in the cd slot .. Perfect location and will work great for the Garmin..
Old Aug 26, 2013 | 05:49 AM
PSU09MAXIMA's Avatar
Go to Proclip USA and get the lower consol mount had mine for years love it
Old Aug 26, 2013 | 05:50 AM
See here
http://forums.maxima.org/7th-generat...e-v-cable.html
Old Aug 26, 2013 | 07:37 AM
Max2013's Avatar
Originally Posted by PSU09MAXIMA
Thanks, that really looks slick! I would mount a Garmin GPS rather than an iPhone. If yours was turned landscape instead of portrait, would you still be able to not obscure access to other dash controls? Any suggestion on Garmin cradle? Also, I'm having trouble visualizing the wire routing. I really like the look of your setup..
Old Aug 26, 2013 | 05:15 PM
Yeah it's got enough room and doesn't block anything
Sent from my iPad using MaximaOrg
Old Aug 27, 2013 | 07:59 AM
Just go to Proclips website pick the car mount and then your device and you're good it will give you the mount you need there
Old Aug 29, 2013 | 03:55 PM
Max2013's Avatar
Funnyman, How do you run the wiring when using the Mountek? Do you use the cell phone version or the 6000g? Thx
Old Sep 12, 2013 | 04:56 PM
Max2013's Avatar
Mountek 6000g
I am going to use the Mountek 6000g as at least a temporary GPS solution. Hopefully will have it next week. Anyone using it have suggestions on running the wiring? Also, do you just leave it setup or dismount it each time when leaving the car? Thks!
Old Sep 12, 2013 | 06:47 PM
funnyman82's Avatar
Sorry didnt see your last post.. I haven't used the mountek for my gps before buy am pretty sure it will work. In terms of running the cables I have run a power cable from the center console armrest area through the center console toward the radio and brought it up. It's the cleanest way without seein wires.
Old Sep 13, 2013 | 12:09 AM
slicknick's Avatar
Proclip with my iphone has gps. drilled a hole in the side of the center console and ran the usb through the middle and up to the pro clip. Looks real clean and simple to just get in and dock the phone.
Old Sep 14, 2013 | 07:35 PM
whit's Avatar
which pro clip dock are you guys using Iphone 4s/4 with Case...
Old Sep 15, 2013 | 11:37 PM
slicknick's Avatar
Yes. I have the one that has the usb connected. Will be upgrading to the new one once in come out so need a new dock.
Old Sep 23, 2013 | 10:56 AM
alexdi's Avatar
You don't need a Proclip. I went through this earlier. I initially had it suctioned to the center screen. It would fall off sometimes and until I put a screen protector on the LCD, the suction cup was leaving a residue.
I switched it to a vent clip mount for the left vent. I ran a wire from the fuse box up the insulation, so there's only two inches of exposed power wire. It's perfect. It makes no noise, doesn't get in the way, doesn't look ugly, and doesn't fall off. Oh, the clip was under $10. I think this is far and away the best method of mounting a Garmin.
Amazon.com : IG-A03: i.Trek Vent Mount for Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270, 205, 205W, 255, 255W, 265T, 265WT, 275T, 500, 550, 680, 750, 760 : Gps Vehicle Mounts : Electronics Amazon.com : IG-A03: i.Trek Vent Mount for Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270, 205, 205W, 255, 255W, 265T, 265WT, 275T, 500, 550, 680, 750, 760 : Gps Vehicle Mounts : Electronics
Old Sep 26, 2013 | 03:16 PM
Max2013's Avatar
I tried the Mountek 6000g CD slot mount for my Garmin, but it didn't work out for me. Jiggled too much on anything but perfectly smooth road. Still looking..
Old Sep 26, 2013 | 07:28 PM
funnyman82's Avatar
Sorry it didn't work out for ya.. Mine does shake but I am not looking at my phone while driving constantly..
Old Oct 1, 2013 | 01:44 AM
alexdi's Avatar
I love being ignored. Good luck, OP.
Old Oct 1, 2013 | 04:26 AM
zoemayne's Avatar
try this its working for me: iOttie Windshield Dashboard Car Mount
Amazon.com: iOttie HLCRIO101 One-Touch XL Windshield Dashboard Car Mount Holder for Galaxy S4/Note 2 - Retail Packaging - Black: Cell Phones & Accessories Amazon.com: iOttie HLCRIO101 One-Touch XL Windshield Dashboard Car Mount Holder for Galaxy S4/Note 2 - Retail Packaging - Black: Cell Phones & Accessories
There are different sizes/versions available search amazon.
Old Oct 1, 2013 | 07:32 AM
Max2013's Avatar
Thanks! Sounds like this would be much more stable than the CD mount. I assume you have it on the far left vent on left side of steering wheel. I like that it might be more hidden from prying eyes there, am I right? I am not an expert at wiring.. Where does your wire come out? Thanks again for the help.
Old Oct 1, 2013 | 02:04 PM
Max2013's Avatar
Thanks Zoe... Looks like good option, but I'm looking to keep it off the windshield or top of dash.
Old Oct 1, 2013 | 04:35 PM
zoemayne's Avatar
I dont have a maxima yet but I think the suction cup can fit in the flat space below the shifter... in front of the arm rest.
Old Nov 7, 2013 | 02:36 PM
Max2013's Avatar
I am still searching for a solution for mounting a Garmin GPS. The inconvenient locations of the power outlets seem to compound the problem for me. Wish the Max had the handy cubby hole below the center of the dash like the Altima, or at least a power outlet there... But it doesn't... Any other suggestions out there?
Old Nov 9, 2013 | 04:54 AM
Envymynissan's Avatar
Others have given you some good options. I am using proclip myself with waze from my cell phone. I would add the ram mount. They have flex arms that bolt on to the passenger seat or that use your cup holder. But if you want permanent with no wires, replace the headunit.
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
