09 sunroof problem
Old Dec 9, 2013 | 09:48 PM
kglow's Avatar
09 sunroof problem
Just bought a real nice 09 Maxima and when I go to open the sunroof it will only open about 2 inches at a time. If you continue to press the button it will open all the way after 10 or so pushes. Same as to close it. Any ideas???? Thanks
Old Dec 9, 2013 | 10:23 PM
weezyfwayne's Avatar
Is it the double sunroof or the regular one
Old Dec 10, 2013 | 03:02 AM
Tommy6905's Avatar
Sounds like it needs a reset, I use to have to do this with my 04 maxima...honestly can't remember how it was done though
Old Dec 10, 2013 | 06:06 PM
kglow's Avatar
anyone know how to reset???? it is a single
Old Dec 10, 2013 | 07:04 PM
Richard66's Avatar
If you just bought it then you should take it to the dealer to fix. They must have offered a 30-60 day warranty. There could be more at play here than a reset, ie: bad motor. Is the roof still watertight? I would be interested in the outcome as I have a 09.
Old Dec 10, 2013 | 07:18 PM
Tommy6905's Avatar
This is for the 6th gen maxima but is imagine it'll work, good luck
INITIALIZATION PROCEDURE
If the sunroof does not close or open automatically, use the following procedure to return sunroof operation to
normal.
1. Push the tilt up switch and start the tilt up operation.
2. Release the tilt up switch once, press the tilt up switch again, keep pushing the switch until lid pops up.
3. The glass lid will more toward tilt up direction and will be stopped mechanically, and then it will be automatically
fully closed. (keep pushing the switch during this operation)
4. Release the switch again, and push the tilt up switch within the first 10 seconds. (keep pushing the switch)
5. After 4 seconds, the glass lid will be automatically operated in sequence of tilt down, slide open and slide
close.
6. After the glass lid stops, release the switch 0.5 second later. (keep pushing the switch during this operation)
7. If slide switch operates normally, this initialization is done.
Old Dec 12, 2013 | 10:32 AM
Propa Teknique's Avatar
This isn't on topic but related. My pano roof squeaks when opening and closing. What can I use to stop the squeak?
Old Dec 12, 2013 | 11:30 AM
Tommy6905's Avatar
This won't be much help to u if you aren't going the dealer any time soon , but on my last car I had the same problem brought it in..the dealer put some type of yellow grease on it and it solved the problem. No charge either
Mar 12, 2020 12:06 AM
Blkkn8
Sep 15, 2015 06:57 PM
Vequity
Sep 10, 2015 05:26 AM
mikebla
Sep 3, 2015 05:37 PM
