converting to HIDs
Old Apr 18, 2014 | 03:47 PM
thatdudesurya's Avatar
converting to HIDs
I have ordered H11 6000k bulbs with ballasts, but I am not sure whether I need a canceller or relay? I have the stock maxima with halogens
Old Apr 18, 2014 | 03:50 PM
Amerikaner83's Avatar
don't drop HID in the halogen housings
Get projectors and do it right. Either 7th gen OEM projector headlights or retrofit the current ones.
Old Apr 18, 2014 | 04:13 PM
I hope you got H11B bulbs or get ready for return wire shadow in your output.
But no, you don't need any cancellers. I do suggest a relay harness though.
Old Apr 18, 2014 | 04:34 PM
escblads's Avatar
Hmmm... all 7th gen Maximas come with projectors, either halogen or HID. Really the only difference between the outputs is how evenly the light is distributed; halogen is more focused towards the center at the cutoff, HID is wider and smoother light distribution.
Old Apr 18, 2014 | 04:36 PM
Unfortunately I didn't get the xb h11s, and I haven't ordered the relay. Will I experience problems without it?
Old Apr 18, 2014 | 05:00 PM
Also, after researching I've seen a lot of posts stating that a relay hardness isn't needed on a 35W kit, but it on a 55W.
Old Apr 20, 2014 | 07:59 AM
Grego214's Avatar
Get the relay and do it right the first time. It would be different if we could just access our headlights from our engine bay but we can't. You'll regret not putting it in then having to either take off your bumper or jack the car up and take the front wheels off to redo your HIDs.
Old Apr 21, 2014 | 06:16 AM
smooth703's Avatar
ive had mine in for over a year without a relay havent had a single issue
Old Apr 21, 2014 | 06:37 AM
mjhuffer's Avatar
I second this. It simply depends on the amp current draw of your 55W ballasts. I got 55W OPT7 AC slim ballasts and haven't had any issues. Each halogen low bulb has a 15amp fuse protecting the wires. The ballasts I found won't exceed that amp draw even during the initial firing. I do notice a difference in my dad's HID stock projectors and my halogen projectors. Mine are a lot more focused toward the center while his are spread out. Still really good cutoff with the halogen projectors.
Old Apr 21, 2014 | 05:20 PM
Thanks for the replies and advice. I didn't order the relay because I am getting a 35W. If I'm not satisfied, I'll end up getting a 55W with a relay.
Old Apr 22, 2014 | 04:57 AM
mjhuffer's Avatar
I was honestly thinking about it just to be safe but it was one more thing I was going to have to wire and run and I just didn't feel like doing it. It's not a bad idea and can't hurt anything but I already have a good deal of things hooked up to my battery so it would be hard finding space.
09maxshawn11
Sep 30, 2015 10:28 AM
sliptap
Sep 30, 2015 05:57 AM
lrb6805
Sep 18, 2015 07:07 PM
Vistance
Sep 17, 2015 05:17 AM
carid
Sep 9, 2015 05:06 AM
