Automatic window problems
Old May 28, 2014 | 07:46 PM
14GmMax's Avatar
Hey guys although some of you disagree with the whole intake concept I wanted to give it a try so I just finished installing it in which I removed the negative battery terminal for the installation. Once everything was done and I was finished driving I noticed my two front windows would go down automatically but not back up automatically. Is there a setting for this or shouldn't it be auto because prior to disconnecting the battery I never had this issue.
Old May 28, 2014 | 08:30 PM
tonydatigeryo's Avatar
If I remember correctly, trying turning the car on to accessory (don't start the ignition). Roll a window all the way down. Roll one up, holding up the entire way and for an additional 5 seconds. Roll it back down and test if the auto up for that window works. I'm on on my cell so I can look it up easily right now but I believe that's how to reset the auto up.
Old May 28, 2014 | 08:38 PM
ThinBlue82's Avatar
This is correct.
Old May 28, 2014 | 08:41 PM
14GmMax's Avatar
Thanks a lot guys appreciate it!
Old May 29, 2014 | 06:28 AM
Propa Teknique's Avatar
A friend of mine needs this. Good info. Thanks!
Old May 29, 2014 | 07:03 AM
Bossman150's Avatar
Thanks! I had this same issue.
Old May 29, 2014 | 08:17 AM
Tommy6905's Avatar
What works for me, one window at a time....roll window all the way down, then go up half way, stop, then continue all the way up and hold for about 5 seconds. I'm not sure if stopping half way makes a difference or not but that's what works for me, good luck
Old May 29, 2014 | 12:08 PM
14GmMax's Avatar
Ok Im going to try once it stop storming, Thanks guys!
The Frye
Feb 3, 2019 08:34 AM
thenewguyy
Sep 12, 2015 11:12 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
