No sounds in trunk speakers non bose system
Old Jun 15, 2014 | 10:30 AM
tiger2380's Avatar
I have an Pioneer x4600bt radio install in my max. I just notice that I don't have any sounds coming from my trunk speakers. I'm not sure if it always like that or what.
I have all wires hookup correctly, I tested for continuity and everything. Can someone point me into the right direction?
Thanks.
Old Jun 15, 2014 | 01:49 PM
Shipwreck's Avatar
The rear deck? Did you tinker with anything back there? They shouldn't have gone out.
It's also possible the amp went out.
Old Jun 15, 2014 | 05:06 PM
Johnnyru's Avatar
I know you'd like to rap me in the mouth for this, but did you check your "Fade" control? It might be set on Front only. You said it might never have worked...just a thought
Old Jun 16, 2014 | 04:21 PM
tiger2380's Avatar
Thanks for your reply. Yes, I check the fades. When I move the fade to the back, only the door speakers work.
I ordered another wire harness and hopefully that will fix the problem.
Old Jul 22, 2014 | 04:07 PM
tiger2380's Avatar
Still no sounds from my trunk speakers. I replaced the harness and nothing.
I notices that there is an another box beside my amp, does anyone know what that box is? I can take some pictures if you want me to.
Also, how can I checked the fuse on my amp? I don't have a custom amp, just the one that came with the car.
Thanks.
Old Jul 22, 2014 | 04:58 PM
Nopike's Avatar
The box next to the amp is the Bluetooth control unit. Is subwoofer out turned on and set properly in your radio?
Old Jul 22, 2014 | 06:44 PM
tiger2380's Avatar
Thanks. Didn't know that.
Yes, the subwoofer is set to on in my radio and I checked all of the audio settings. Still nothing. I'm going to attach my the original radio again and see if they will work.
I have a Avh x4600bt by the way.
Old Jul 22, 2014 | 07:04 PM
Nopike's Avatar
Is the output of your radio to the sub woofer the proper signal level. Pre amp out?
Maybe you can check the audio section of this forum and see if anyone had an issue like yours when installing a new head unit.
Old Jul 22, 2014 | 07:20 PM
Nopike's Avatar
I'm looking at the wiring diagram for the non Bose and it shows that the same signal sent to the rear door speakers are the ones used for the subwoofer. That probably means that the signal is already amplified and is not a pre amp (RCA) out. You probably can not use a preamp out signal from your head unit and feed it to that subwoofer amp. Sorry I am learning on the fly and do not want to confuse you. I would expect others who installed after market head units to have had similar issue.
Old Jul 22, 2014 | 07:35 PM
mjhuffer's Avatar
Which harness are you using. The one that utilizes low level inputs or RCA inputs?
DJLAX152
May 4, 2021 11:46 AM
9aj9
Apr 5, 2020 12:11 AM
TheMafia
Sep 4, 2015 08:26 AM
A32goldylocks
Sep 2, 2015 06:39 AM
